Hi guys
I download z v-carve demo version to check my new router that I build my self. But I have difficulty using the program because it can be setup in inches only not in mm.
Help please,,,,,,,,,,, any one
Hi guys
To change from inch to mm, try this.
Start Vcarve:
1) Edit
2) Material Size
3) Units (it defaults to inch, change the radio button to mm)
4) Click the OK button
Free DXF - vectorink.com
After you change from inch to mm, you'll need to redo the toolpath (code), the program will let you know, that this needs to be done anytime you change the material size, etc...
Perfect answer - Thanks Switcher
serocco - I hope your new router is up and running and if you need assistance or have any questions drop an email to [email protected] and we'll see if we can help out.
Tony
thanks guys thats help a lot keep the good works running.
cheers
cheers
