Hi folks maybe some one out there could help me with this one. I have just placed a Maho mh500 mill in my workshop. But after I palce it I found out that the machine is unstable. All four legs has preassure to the ground but if I by hand press the spindle backwards I'm able to tilt the complete machine lift the front legs from the ground). I have the manuals for the machine and it says no fundament needed. And the machine sould not be bolted to the flor but rest on rubber machine feets.
I have a couple of pictures of the machine and as you can se the rear feat almoust is at senter of the machine. I cant find any other place to insert legs than the 4 holes. The legs seems to be 50 mm (2 inch) Higher than original.
What should I do? And if anyone else Have this machine how is your machine placed.
