585,591 active members*
2,519 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Cycle Start output on Fanuc 15-MA
    Dec 2007
    Hi, I would like to detected with an electronic module when the NC is running. In a lot of Fanuc based machines there is a "Cycle Start" button with a lamp that is on when the NC is running.
    Unfortunately on this machine this lamp is not present. I would like to know if the Fanuc 15-MA controller always provide a "Cycle Start" lamp output or this is specific to the machine builder choice.
    Is there another way to detect the NC is running?
    Thank you for your help!
    Dec 2007
    I found a Fanuc 15 manual and it talks about the status outputs:
    - 29.6 Automatic operation start lamp signal: "This signal is sent out when automatic operation is being activated."
    So it seems this signal should present by default on the controller. So anybody as an idea where I can found this signal?
    The machine I'm working on is a Moore G4139.
    Dec 2006
    84
    This is a signal internal to the controller that can be used by the PMC. If you're wanting to put a cycle light on the machine you would have to edit the ladder using this signal and tie it into a physical output to power the light.
    Dec 2007
    Hi codyst. Thank you for the fast answer. I'm a newbie on Fanuc, could you please explain a little bit further about the ladder editing? I tried to search in the forum but I didn't found something useful (or at least I think)
    By the way on a maintenance manual there is a reference about a STL signal (cycle start lamp signal) on the control unit PCB (A20B-1003-2040. There is a jumper to set common or 24V output for STL, SPL, ecc... signal.
    So my question: are we sure there isn't already a signal on the main controller unit for the cycle start?
    I'm going in the wrong direction? Please help...
  1. Cycle start not working - SL3B
    By andy.f in forum Mori Seiki lathes
    Last Post: 02-15-2008, 07:30 PM
  2. Canned cycle output in Gibbs lathe
    By naytep in forum GibbsCAM
    Last Post: 08-30-2007, 08:38 PM
  3. Remote cycle start
    By REVCAM_Bob in forum Fanuc
    Last Post: 03-19-2007, 01:08 AM
  4. Remote cycle start?
    Last Post: 01-20-2007, 05:59 PM
  5. Cycle Start button
    By kaleem1 in forum Mach Software (ArtSoft software)
    Last Post: 12-24-2005, 09:05 PM
