585,748 active members*
3,500 visitors online*
IndustryArena Forum > CAM Software > FeatureCAM CAD/CAM > Lathe Package need help
Results 1 to 11 of 11
    Nov 2007
    5
    Today we sat thru a online demo of Feature Cam's lathe package.We thought it looked pretty nice,the pricing may of been high compared to Master Cam or Gibb's.Thought what a better place to go and get feedback about the lathe package than a Feature Cam Forum.Please tell pro's and con's.Some thing's are better than others.I appreciate your help.THANKS
    Sep 2003
    363
    I don’t have enough experience with the others to give a fair comparison. My experience using FeatureTurn is with single spindle turning centers and no live tooling. I haven’t seen a CAM package for turning that is easier to learn and seems infinitely customizable.
    Gary
    Nov 2007
    5
    Thanks for the input Gary.Our shop is single spindle and no live tooling.
    Mar 2006
    42
    I have used the turn/mill interface extensively and really like it its basically 2.5 D milling on a 4th axis works awesome and no new interface to learn
    Apr 2010
    Can you get feature cam to select the tools that you want it to? When I looked at this product it seemed intent on making its own decisions on type of tools to use and not in an intelligent way. Was this just me not understanding the program?
    Feb 2006
    992
    Quote Originally Posted by kantarr View Post
    You can select tool you want.
    The best way to learn is trial error.
    Apr 2010
    yes that is correct but can you teach feature cam to select the tool that you want it to select, first time?
    Apr 2010
    I see that no one has taken the time to answer my last question re Feature Cam so untill otherwise advised I will take that as A no.
    Jul 2007
    148
    I've only seen a demo of FeatureCam but in regards to your question, could you perhaps "force" it to use the tool you want by making a special tool table for it to program with?
    Feb 2006
    992
    Under Custom Manufacturing -> Machining Attributes. To Modify tool double click on the one you want edit, click Properties then change to the one you want.
    BTW, it's in the manual.
    Jun 2008
    1838
    When I start a new job I already know what tooling I will be putting in the machine so I simply create a new "Tool Crib" first and then select that Crib for use with that program.
    The software will then use tooling from that Crib only and it is then real easy to have the right tool every time.
    You should set up your Tool Library with tooling created that you actually own and use and delete the rest, less confusion that way.
    Any time I get a new tool it is added to the main tool library and then just added to any particular Crib as required.
    The software is very, very good, I have used other cheaper alternatives and they don`t come close to FeatureCAM IMHO :rainfro:
    Regards
    Rob
    :rainfro::rainfro::rainfro:
  1. CNC Package
    By automationtechinc in forum News Announcements
    Last Post: 03-29-2007, 02:06 AM
  2. Live tooling in Lathe package?
    By Linchpin in forum OneCNC
    Last Post: 04-19-2006, 10:13 AM
  3. Sherline Ultimate 4-axis CNC Mill and Lathe Machine shop package
    By CorporalChaos in forum Benchtop Machines
    Last Post: 01-21-2006, 07:10 PM
  4. Looking for a good CNC lathe package
    By castguy2003 in forum Uncategorised CAM Discussion
    Last Post: 09-22-2004, 10:06 PM
  5. another package
    By Laff Riot in forum Uncategorised CAM Discussion
    Last Post: 06-07-2003, 09:28 PM
