I'm new here, so go easy on me if I missed something...
I need to machine a simple tool, a tapered dowel, 14.5" long. Widest part is 1" diameter; smallest part is 5/32". There are two untapered sections.
I do not normally use CAD software but I downloaded "Art of Illusion" which I have used to create a drawing (.aoi). Art of Illusion is also able to export to .obj, .pov, or VRML, if one of these formats is more useful to you. When creating the drawing, I did not see a way to set units, so I assigned the various points in the drawing as numbers with an assumed unit of 1 inch.
If the drawing is unsuitable for production, it may still be suitable for you to see how simple the shape of this tool is. It took me 5 minutes to make this drawing on a program I have never used before, so I can provide a detailed enough description for you to make your own drawing.
I can wait several weeks for this part... I don't have a big budget for it, however. Material would be something hard that does not deform significantly at temperatures of 100-200°C, but otherwise machinist's choice. Machinist will provide material, which I will pay for.
If the price is right (please include materials, labor, and shipping to new york city in your quote) I will order a second piece. It is a hollow tapered tube which is slightly wider and a little bit shorter.
I zipped the .aoi file since this forum software doesn't allow files with an extension of .aoi. Including a .png in case you want to see roughly what the tool would look like.
Thanks in advance for your bid!
