585,775 active members*
4,423 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Chinese scales to position the tool
Page 2 of 4 1234
Results 21 to 40 of 75
  1. #21
    Feb 2007
    31
    Robin,
    Very nice work.
    I've been playing with a similar idea, but took the approach of grabbing the position after it has been processed by the DRO. Your way is MUCH better. Also, buffering the signal back at the source is brilliant. It solves one of the biggest problems people have with their DROs, noise.
    For faster positioning (I'm sure you've already considered this), you could do a hybrid control operation, where you use the stepper w/o feedback to get close, pause while the scale catches up, then finish with the scale providing the feedback.
    May I be your US distributor?
    - Don
  2. #22
    Mar 2007
    534
    Quote Originally Posted by dleroi View Post
    Of course you can, but maybe I should finish it first
    I'm now writing a quick g-code interpreter and 24 bit x,y,z positioning system in machine code. I've already done it in Borland C, it's not hard. Accelerations will be much easier without having to compete with Bill Gates for the cpu timer interrupt
    My brother is a computer wizard and has given me a zippy algorythm for 'next point on an arc' without square roots. Can't wait to try it out
  3. #23
    Sep 2003
    1469
    Smile Outstanding Idea
    This is a groundbreaking project, and rightly so it is currently focused at the electronically gifted.
    Possibly after it is completed I hope it can be simplified for us among the electronically challenged.
    Keep the photos and details comming.
  4. #24
    Nov 2007
    197
    great thread!
    at first i thought you mean scales as in weight, which could also be great for setting z depth? if you picked a scale that also had rs-232
    Here is something that i put together along the same lines (using existing computer interfaces that is)
    ibm trackpoint mouse used as an edge locater
    [ame="http://www.youtube.com/watch?v=3q58oVZCmB0"]YouTube - Find Center Of Slot - Edge Probe Mach 3[/ame]
  5. #25
    Mar 2007
    534
    Quote Originally Posted by Mr.Chips View Post
    Here's the pendant, haven't cased it yet...
    The main board has 3 spare sockets for extra goodies like pendants and tool height detects. They all identify themselves so it doesn't matter which socket they plug in to.
    Everything is RJ45 sockets and patch cords.
    I thought 3 goody sockets would be enough
    There's also an RJ45 plug with a serial connection in case I want to do a DRO type display and add some extra buttons.
  6. #26
    Jan 2008
    59
    I sure don't understand it, but sounds cool!!
    Sub'd
  7. #27
    Jan 2004
    668
    This pendant, is it like hand, held type. I don't see a big dial for speed. Does this mean it can jog axis at a fixed speed? I am all but brain dead when it comes to electrics and stuff. I'm looking for a very low dollar joging pendant that will help in positioning to a zero zero home and set the Z at zero zero also. How much did this cost, can it be reproduced by a novice like me??? PM me I'm interested in learning more.
  8. #28
    Mar 2007
    534
    Quote Originally Posted by SPEEDRE View Post
    I currently jog with a pop up on the screen (see pic) but it's a PITA trying to see behind the tool tip while straining to hold the mouse over a north south button.
    I have an on screen speed button that toggles fast/slow, (have to be careful that the fast is not so fast that I can't stop it abruptly without losing steps because if I allowed for accelerations it would overshoot). For this pendant I thought I might pop up a window on the screen, use the green button to toggle it fast slow and the red to accept the position. Haven't got to that bit yet...
    Unfortunately you neeed a pendant that will interface with your setup, this thing will only work plugged in to my box of tricks, not a lot of use to you.
    Still writing Gcode interpreters. I just came up with a snappy 'find the integer hypotenuse' function for the arc radius when I get i and j. One that has minimal multiplies and doesn't involve finding 48 bit roots or any divides. Can anyone improve it?
    Given the x and y offset, add one quarter of the short offset to the long offset and call it best guess at the hypot, gets it within about 4%. Calculate x squared plus y squared, square my guess and subtract it. That shows which way I'm out and leaves me the error. The difference between n squared and n+1 squared is 2n-1, a magic number that changes precisely 2 as you increment/decrement the root. I subtract that from the unsigned error until it carries and I have the hypotenuse
  9. #29
    Sep 2006
    1738
    That is really bad ass! I like your solenoid controlled probe Really cool stuff man, love the pics of the circuitry!
    -Speed
  10. #30
    Jul 2005
    969
    well now that you have one user interested in distributing your stuff in the US id be happy to do the same in Canada this is a wonderfull idea
    The opinions expressed in this post are my own. -Les opinions exprimé dans ce messages sont les mienne
  11. #31
    Mar 2007
    534
    Quote Originally Posted by ataxy View Post
    The idea's okay but my brain is starting to fade. I just wasted 8 hours coding a hypot function I don't need. Got to the circle/arc drawing part and it needs the radius squared :tired:
    I can use the 4% algorythm to adjust the feedrate for slopes, close enough for that
    That's the USA and Canada sorted, perhaps best not to take advance orders though
    What exactly does G28 do
  12. #32
    Jul 2005
    969
    g28 as in gcode its a return to home call wich tells your machine to return to its home position
  13. #33
    Mar 2007
    534
    Yes, but if I find...
    G28 Y0
    Does that mean set the home position to Y0.00, current X and Z, or, set it and go to it, or, what?
    If the next line was...
    X0
    presumably I revert to the previous G00, G01, G02, G03 or drill position whichever came last, because G28 is in a different modal group, probably
    The definitions I can find are so vague I forsee problems with this. Best keep the gcode interpreter very open ended and easy to tweak. Fortunately I have distributors who can find the bugs
  14. #34
    Jul 2005
    969
    yes then it is g28 return to home as y0 and then x0 some program will often only do g28 z0 as to tell the machine to rise its head for the tool change
  15. #35
    Mar 2007
    534
    Wow, now I come to write it, this is one weird stepper driver
    I do my best programming when I'm out walking the dogs at lunchtime, have to be away from the keyboard so I can get my ideas straight. Here's a progress update
    There is a worry because the tool position must be allowed to get ahead of the scales. The scales only report 50 times a second and I need to step faster than that. If it gets ahead it has to make quick decisions. If the scales disagree with the screws, the assumed tool location suddenly changes under my feet.
    What to do if the tool grabs and the updated position from the scale overshoots beyond where we are prepared to go? I think the answer is that I only become anal about the scale position for the final light pass, I am more forgiving while roughing out and I don't care about a G0 until it gets to the end of it.
    Tight Gibbs should help. Backlash correction is, of course, totally automatic. I may insist that the X and Y axes have approximately the same step resolution. (No need to tell me the step resolution, I can measure it).
    With the scales resolving .005mm (.0002") I still get one count of jitter. Don't want to slam a fast moving stepper in to reverse just because it sees a slight jitter. Very happy to tweak a minor axis though.
    I have a cunning plan that allows the processor to unpack the gcode and run about 30,000 steps ahead of reality without losing track of where it actually is. If the mill has an oops requiring operator assistance, I want to be able to back track real easy.
    I reckon full speed on all 3 steppers is around 6000 steps per second and I should allow for twice that to get a good safety margin. There's simply no time for complex maths when it's deciding which way to leap or whether to stay put.
    I'm stepping in sequence so no two drivers switch at precisely the same moment and I allow one step delay for the direction line to settle before moving. Probably unnecessary but comfortably reassuring
  16. #36
    Mar 2007
    534
    PS: Just thinking about the G0. I can wind the speed up until the motor starts to lose steps then back off a bit so it goes as quickly as possible. That sounds like real fun, I'll enjoy doing that bit
  17. #37
    Mar 2007
    534
    Project update
    Been a while so thought I'd do a quick update
    I was writing a g-code reader and it was becoming unwieldy so I've junked it and started over doing it with look up tables and structures.
    You now feed it raw g-code, byte at a time. The input character goes straight to a 128 word lookup table, covering the entire ASCII character set, and it instantly knows exactly what to do.
    Doing it this way makes it totally expandable without risk of turning it in to a garbled, hard to understand, bug-ridden mess.
    What comes out the other end of my new g-code engine is a concise list of instructions for everything it can do and error messages for everything it can't.
    If you haven't guessed, I'm rather pleased with it
  18. #38
    Mar 2005
    1673
    I wish I had something useful to say but I don't other than nice one, keep up the excellent work and keep us posted please.
    John
  19. #39
    Jun 2008
    18
    Robin, I'd love to hear some more updates/progress on the system you're working on
  20. #40
    Apr 2008
    5
    Is that some type of universal proto board ? Seems like a LOT of connectors on there!
    I did about the same for my mill just for the readout. I used an 8pin AVR chip for each one that did away with the need for any extra circuitry for reading the signal. The AVR has a built in analog comp with a 1.1V ref available, works like a charm!
    I just soldered the wire connections directly on mine, but have been meaning to make some real plug-in connectors since I now have PCB making capabilities.
Page 2 of 4 1234
  1. Chinese machine tool show set for 2007
    By r.hung in forum Trade Shows / Webinars / Other Events
    Last Post: 07-28-2006, 07:08 AM
  2. Tool position indicator
    By Jalex in forum DNC Problems and Solutions
    Last Post: 06-24-2006, 07:25 PM
