585,996 active members*
4,005 visitors online*
IndustryArena Forum > CAM Software > Mastercam > wide screen stretching issues
Results 1 to 8 of 8
    Dec 2007
    8
    I started using a 22 inch wide screen for a monitor and now Im seeing oval shaps instead of circles. Also printing the same way. does anyone have a clue of what to do ?:idea:
    Jun 2007
    3757
    Talking Try this.
    View the screen at an angle. (LOL) sorry about that.
    I just decreased resolution on my ACAD machine to fix circles.
    Nov 2007
    1702
    Change your screen resolution to one of the widescreen settings. Widescreen isn't supposed to stretch your image. It's supposed to give you more desktop space.
    It's going to vary by the video card and drivers you have installed. Sorry that I can't be more specific than that.
    Greg
    Nov 2005
    256
    I don't know about Mastercam, but Autocad had a utility all the way back to the 1.X or 2.X days in DOS to allow you to make circles look round on the screen. I would expect Mastercam should also.
    Apr 2003
    3578
    set it to the native screen setting this will set it right.
    I run dual 22" at home and dual 24" at the office. no issues.But have seen this because of the incorrect settings.
    Cadcam
    Feb 2006
    61
    Re: wide screen stretching issues
    I also have problems when I use mastercam in a wide screen laptop, when setting the stock , the OK tick is below the screen view
    as most laptop manufacturers today ship their units with wide screens, I believe that its a serious issue.
    can anyone please suggest a solution for this?
    thank you
    Mariano
    Dec 2008
    3109
    Quote Originally Posted by rasta View Post
    thank you
    Mariano
    Try setting the screen resolution of the laptop to a greater resolution
    - this should make the dialog boxes in Mastercam smaller when compared to the actual screen size on the laptop
    - I have seen stretched windows display a circle as an oval...this also is a PC graphics setting correction......none of these issues are Mastercam related
    Apr 2003
    3578
    This why I alwas prefer to get my laptop with the resolution of 1920x1080 as this can cause this issue.compared to say the lower screens of 1366x768. these are native screen settings. this make a difference.
    Not all screens will let you go higher then there native settings. 15" laptops tend to have the 1366x768 but you can get them with the higher. I found that 1366x768 just makes it as you have to some times move the prompt windows to get to the ok buttons at the bottom. I have all Dell Precision Laptops some have the higer res and some have the lower so I see both. but on these laptops I can buy a new higher res screen and repalce them. most laptops you cannot do this.
    Cadcam
  1. "Fit To Screen" issues
    By t_chance in forum Surfcam
    Last Post: 02-27-2013, 08:22 PM
  2. Timing belts are 3/4" wide and only come in 3/8" wide?
    By CATCH22 in forum Uncategorised MetalWorking Machines
    Last Post: 01-27-2012, 08:44 PM
  3. Delta 10 / 20 CRT screen issues
    By hmc710 in forum Dynapath
    Last Post: 11-23-2011, 09:40 PM
  4. Probe screen issues...
    By gadget47 in forum Mach Wizards, Macros, & Addons
    Last Post: 03-05-2010, 09:09 PM
  5. Screen stretching
    By escott76 in forum Mach Software (ArtSoft software)
    Last Post: 07-28-2009, 10:14 PM
