585,737 active members*
4,782 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Making Large "Turner's Cubes" on an Engine Lathe
Page 1 of 4 123
Results 1 to 20 of 107
    Well, I got bored doing production in my little shop, so I decided its time for a little fun
    For starters, I have acquired two chunks of 303 Stainless! They are 5" dia and 3 1/4" long! So I setup my little horizontal band saw, and cut the bar stock into cubes around 3 1/8 x 3 1/8 x 3 1/8. Then I used my face mill to rough them down to around 3.010" cubed. Lastly, I put new carbide inserts into my face mill, and took one final pass on all six sides leaving a nice smooth, flat, parallel, perpendicular, and square cube! Then I drilled a 1/2" hole to the center o the cubes from all six sides.
    Widgit
    Attached Thumbnails Attached Thumbnails 100_2796.JPG   100_2797.JPG   100_2798.JPG   100_2799.JPG
    Now I need to make a fixture plate that mounts on my lathe's spindle, to do that I will use the back plate with D1-4 cam lock studs from my 3-jaw chuck!
    I found a nice block of aluminum in my scrap pile, and machined one surface flat and counter-bored it to fit snuggly on the backplate. Then I transferred the three holes from the backplate to the aluminum block, and drilled & tapped them for 1/4-20 UNC around 3/4" deep.
    After fastening the block to the faceplate and to the lathe's spindle, I turned the OD and face true. Then I removed the block from the faceplate, and put it in my Mill's vise, I had to remove one of the jaws to get it to fit!
    Then with a 1/2" 2-flute end mill, I machined a square pocket in the center of the block around 1/8" deep. In order for the cubes to fit in this nest, I had to go and extra 1/4" past each corner with the end mill.
    Now the cubes fit snuggly in the center of the block!
    Widgit
    Attached Thumbnails Attached Thumbnails 100_2807.JPG   100_2808.JPG   100_2809.JPG   100_2810.JPG
    Then with a drill chuck, I drilled 4 holes in the block and tapped them for 1/4-20 UNC around 3/4" deep. Now I need to make some custom straps to hold the cube on the corners where it will be strongest as I remove material with the lathe.
    The clamps are 1"x1"x3" aluminum, with a .290 dia hole down the center of the long side. Next I milled a step in the end and in the side of each clamp, so it will hook on to the cubes!
    Widgit
    Attached Thumbnails Attached Thumbnails 100_2813.JPG   100_2814.JPG   100_2815.JPG   100_2816.jpg
    It's been a good day, I have made the fixture and its clamps, and spent a few hours running the lathe! So far I have finished 3 of 6 sides in one of the cubes!
    I can't wait to finish these, as I have always wanted to make one for myself! They look so cool!
    Tomorrow I will finish up the lathe work, and spend a day deburring and polishing!
    Widgit
    Attached Thumbnails Attached Thumbnails 100_2817.JPG   100_2818.JPG   100_2819.JPG
    Jul 2005
    12177
    FUN????? Your idea of fun is one h*** of a lot of work. But I guess you are correct, it is fun when you don't have to do it and are just doing it for the satisfaction of making something neat.
    Some day I plan on making one but I think I will cheat in my lazy old age and program a CNC to do it.
    May 2005
    2502
    Something strangely hypnotic about those cubes. Even one that's spoiled. I have one I started but spoiled a while back. I should get going on another.
    Do you plan on making 2, or is the extra cube for insurance?
    They're even fun to draw in a CAD program:
    Geof, if you're going to cheat with CNC, you need to make a whole series with different things inside. Perhaps one for each suit of cards or some such:
    I've seen some odd things come out of lathes:
    Cheers,
    BW
    Mar 2005
    1136
    Eric, those look great, bet you could sell them.
    I'd always thought a turners cube, as the English apprentices were taught, had undercuts so that the cubes separated, cube inside a cube that can't come out. Lautard in one of his books walks through how. here's a three cube one i made years ago, its 1" sq. Lot of fun just having it sit on the desk because all the non technical people would pick it up and hurt their brains trying to figure it out. lol. its the machinist's equivalent of worry beads so the edges have long since been rounded.
    http://i20.photobucket.com/albums/b2...urnerscube.jpg
    Jul 2005
    12177
    Very nice job Eric.
    But I think it is toss up between the finished cube and the elegant fixturing you built to machine it; both are an impressive example of craftsmanship.
    Quote Originally Posted by Geof View Post
    Very nice job Eric.
    Thanks Geof!
    I have been thinking of making some cubes out of plastic, or aluminum just so I don't have to toss the fixture in the scrap pile
    It was surprisingly rigid, and the lathe was able to repeat nicely!
    Widgit
    Jul 2005
    12177
    Quote Originally Posted by widgitmaster View Post
    Thanks Geof!
    Widgit
    Plastic!!! Cast Acrylic.
    Make them in cast acrylic, polish all the surfaces optically clear and they would look fantastic. Especially if you illuminated them correctly, you would get a prismatic effect in all directions.
    See if you can locate a supplier for blocks of cast acrylic and how much it would cost, I will cover the material cost if it is not too horrendous in exchange for you making me one.
    P.S. Never, ever toss a fixture in the scrap...that guarantees you will need it the day after you tossed it.
    Now that's a done deal!
    As I have already ordered an 8" dia x 7" long piece off eBay!
    Two plastic cubes are in the works
    Widgit
    Jan 2008
    76
    unless i am seeing things wrong ..... i would set the block upright in a small grinding vice.... use a v block to bring an edge to the top... then mount the grinding vice in my mill vice at a 45.... i may be missing some thing tho ... i am at work and am in a bit of a hurry
    dam see what i get for being in a hurry ... i get to be wrong ... i got a chance to draw it up at lunch.... cool blocks
    Quote Originally Posted by Hennessy View Post
    Not everyone can afford a nice Grinding Vise big enough to hold a 3" cube!
    With all the tools and machinery I own, even I don't have one!
    So off to the V-Block and Sine plate it is!
    Widgit
    www.widgitmaster.com
    It's not what you take away, it's what you are left with that counts!
    Two Turner's Cubes made from 303-SS
    Widgit
    Attached Thumbnails Attached Thumbnails 100_2835.jpg   100_2836.JPG   100_2837.jpg   100_2838.JPG
    Jun 2006
    440
    Widgit
    This is really nice work. Kudos on the effort and skill to turn out such an interesting project. Looking forward to seeing the acrylic cubes.
    Suppose you were an idiot and suppose you were a member of Congress. But I repeat myself.
    Mark Twain
    The Cast Acrylic bar arrived today, it is 8" dia x 7.9 long.
    With a little luck I should be able to make 4 cubes out of it!
    Widgit
    Jan 2008
    76
    Widgit
    ya it was one of those things i really needed for one job. used it on a few things but it just sits in the cabinet most of the time.... not exactly a tool u need to have in a shop but its nice.
    looking at your setup i feal like i cheated... i made mine on a vf2.
    whin i get home i will see if i can find the pix of mine. i made one part run with circles and one with ellipses.
    Hennessy
    A little disappointed, but the project must go on!
    Those little sapphire vee-jeweled bearings I had ordered arrived yesterday, and they are too delicate to support the massive weight of the stainless steel cube (1lb 5.4oz) I would estimate a SS cube of 1"x1"x1" would be the limit for something so delicate.
    So as an alternative solution to keep the cube spinning, I have ordered 4 small double sealed bearings. To use them I need to make some little posts to fit into the bearings, and press into the points of the cube!
    The bearings have an OD of .250" dia, an ID of .125" dia, and a height of .1094" Here are some sketches of what I had in mind
    Widgit
    Attached Thumbnails Attached Thumbnails 9670_1_sbl.jpg   DoubleBearingPost.JPG   DoubleBearings.JPG
    Jul 2005
    12177
    A little disappointed, but the project must go on!..... To use them I need to make some little posts to fit into the bearings, and press into the points of the cube!
    Widgit
    Read my suggestion a few posts up, I don't think you need to do anything; just put the corner in the bearing.
    Mar 2004
    439
    Widgetmaster-
    How about making the cubes from Steel and Nickel plating (or magnetic stainless) them and having a rare earth magnet in the top and bottom of the frame, and letting the corners of the cube be the bearing points? Easy to remove, and you could put it back in any orientation.
    Here's a great source for rare earth magnets:
    www.kjmagnetics.com (no affiliation except I've bought dozens of magnets from them)
    NEATman
Page 1 of 4 123
  1. Hawk150-Acramatic2100 "NC Engine Failed"
    By espinja in forum Cincinnati CNC
    Last Post: 12-16-2022, 10:05 PM
  2. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  3. RFQ : 5/8" cubes (6061 alum.) 100/1000/5000 pcs
    By dukejavelin in forum North America RFQ's
    Last Post: 03-08-2013, 03:04 AM
  4. What is this called a "internal side crank engine" ?
    By Andy-7300 in forum I.C. Engines
    Last Post: 07-12-2008, 07:04 PM
  5. "Fixing" bent engine valve?
    By mmmjboner in forum Bending, Forging, Extrusion...
    Last Post: 07-16-2007, 09:40 PM
