585,753 active members*
3,911 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Making Large "Turner's Cubes" on an Engine Lathe
Results 1 to 20 of 107
Threaded View
    Well, I got bored doing production in my little shop, so I decided its time for a little fun
    For starters, I have acquired two chunks of 303 Stainless! They are 5" dia and 3 1/4" long! So I setup my little horizontal band saw, and cut the bar stock into cubes around 3 1/8 x 3 1/8 x 3 1/8. Then I used my face mill to rough them down to around 3.010" cubed. Lastly, I put new carbide inserts into my face mill, and took one final pass on all six sides leaving a nice smooth, flat, parallel, perpendicular, and square cube! Then I drilled a 1/2" hole to the center o the cubes from all six sides.
    Widgit
    Attached Thumbnails Attached Thumbnails 100_2796.JPG   100_2797.JPG   100_2798.JPG   100_2799.JPG
  1. Hawk150-Acramatic2100 "NC Engine Failed"
    By espinja in forum Cincinnati CNC
    Last Post: 12-16-2022, 10:05 PM
  2. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  3. RFQ : 5/8" cubes (6061 alum.) 100/1000/5000 pcs
    By dukejavelin in forum North America RFQ's
    Last Post: 03-08-2013, 03:04 AM
  4. What is this called a "internal side crank engine" ?
    By Andy-7300 in forum I.C. Engines
    Last Post: 07-12-2008, 07:04 PM
  5. "Fixing" bent engine valve?
    By mmmjboner in forum Bending, Forging, Extrusion...
    Last Post: 07-16-2007, 09:40 PM
