Hi.
I decided that I will give my pisa tower (designed by me) out to the public for free use.
It is meant to be cut from 4mm material and with 1.5mm cutter.
If you will use other thickness, scale it to your needs.
If you use bigger cutter as 1.5mm, you will have problems when assembling.
Assembly insturctions:
1. Do not start with the ground plate, You have to start with 2nd floor and then build it išto the 6th floor.
2. Dont add the top floor or any fences yet. Now it is time to build the inner circle from 16 long parts.
3. Now you take the bottom plate and put together the ground floor. When you have it you put it together
with the rest of the tower.
4. Glue together the bottom ground plate for the tower and put something 4-6mm thick on one side of the holes, so
the tower will stay leaned.
There is one spare part for each floor in case you break something
If you build it from 4mm material it will be in 1:100 scale.
Dejan
