585,982 active members*
4,766 visitors online*
Thread: wont planar
    May 2007
    23
    wont planar
    I created a wire frame and it wont planer i have been trying to figure it out for two days now and its beyond me I called bob cad support on demand friday but they never got back to me until i called them again today monday so i thought i would look here for help
    Attached Files Attached Files
    Jun 2007
    65
    It looks like a bad chain.
    John
    Aug 2003
    449
    the problem is with the geometry. There are overlaps where the radius meets the angled lines of the protrusion in the bottom right hand corner. If you clean them up and redraw the radius it works fine. I have attached the part file.
    Regards
    May 2007
    23
    thanks the one is great
    i knew their was a problem somewhere but i dont understand how it happend i used point conect to join lines and fillet to make the curves and i searched for the mistake zoomed in as much as i could and can never find it is their an easy way to locate something like that
    Aug 2003
    449
    I like to use the Chain Select method to find these errors.
    Just enter into selection mode.
    Holding the Shift Key down click on an entity.
    If the entire chain selects, de-select it and try another entity.
    If there are any overlaps or gaps you should be able to find them using this method.
    Regards
  1. program wont run
    By laamar in forum Bridgeport / Hardinge Mills
    Last Post: 02-27-2008, 08:39 PM
  2. Replies: 11
    Last Post: 06-01-2007, 04:03 PM
  3. extrude from planar curve
    By smoker in forum Rhino 3D
    Last Post: 03-21-2007, 11:50 PM
  4. Why wont this work?????
    By epineh in forum CNC Machine Related Electronics
    Last Post: 03-18-2007, 06:44 AM
  5. V20 Changing Planar Tool Path
    By roys29 in forum BobCad-Cam
    Last Post: 11-22-2005, 06:47 PM
