585,996 active members*
4,222 visitors online*
Page 1 of 2 12
Results 1 to 20 of 23
    Oct 2007
    16
    New Engraving software CNC Write
    CNC Write is now ready to download. Get your free demo at http://cncwrite.com
    CNC Write is a brand new engraving program that is designed to make fast work of common engraving operations. The interface is simple and easy to use. No hunting through cryptic menus for options. If you are familiar with writing your own G-Codes, it is easy to make custom font's and symbols to use in CNC Write. CNC Write was not intended to be used for fancy engraving on signs and plaques, However by designing your own fonts and building a font file, that type of work can be done with CNC Write.
    There are two versions, Standard Mill mode and Integrex. The only difference is the Integrex version adds all the features you need for cylindrical interpolation on the Mazak Integrex. Integrexman at integrexmachinist.com can answer your questions about the Integrex modes.
    I haven't decided on a price yet but I can say that the highest it will be is 300 for Mill version and 400 for Integrex. It will very likely be less than that though.
    The only difference between the demo version and the registered version, is the demo version will randomly replace letters with an 'X'. Once you purchase a registration key, and register the program, that will no longer happen. Please note that the 'X' will often be a different width than the letter it is replacing, this may cause some overlap with that X and the next letter. This is not a problem with the registered version.
    If demand is high, many new features will be added in the future. Give the program a try and let me know what you think and what else you would like it to do.
    Chris W
    Oct 2007
    16
    Some people were having trouble downloading the font files. Clicking on the link would open the file in the browser window. Now it should prompt you to download them instead.
    Let me know if you have any trouble getting the program to work.
    Chris W
    Oct 2007
    16
    The price for CNC Write has been set. The Integrex version is $299.99 and the Mill version is $199.99. Payment can be made via paypal, there is a link on the registration page on the web site CNCWrite.com Registration page
    Chris W
    Oct 2007
    16
    If you are having trouble figuring out how to use CNC Write, be sure to read the notes below the screen shots on the web site here...
    Screen Shots
    Also note that you can click on each tab and on the different sections above the tabs to get notes on how to use each group of settings.
    Here is a video of CNC Write engraving on mill with a rotary axis.
    Video
    Here are some examples of what you can do with it as well.
    Chris W
    Oct 2007
    16
    I have some videos of CNC Write in action on an Integrex and photos of the finished part.
    I have also fixed A minor bug in the way the program calculated the start point of engraving when using a rotory axis, and a small bug with the Integrex using G16, when engraving around the part more than one full revolution. If you have already downloaded the program you may want to download it again if you use either of these features.
    Integrex Using G12.1 Video
    Integrex Using G16 Video
    Chris W
    Oct 2007
    16
    I have a photo and video of CNC Write on a mill using XAZ for engraving using a rotary axis to engrave on a cylinder.
    XAZ Engrave Video 3.6 MB
    Chris W
    Feb 2009
    will this work for a Milltronics Controll?
    Oct 2007
    16
    The program outputs standard G codes. G00 and G01 is all your machine needs to support for standard engraving. The best thing to do is just download the program and try it out. The only difference between the download and the registered version is the free download will randomly replace letters with an 'X'. If you have problems getting it to do what you need let me know and I can help.
    Chris W
    Feb 2009
    58
    just found
    I just found this software looking for a way to do rotory engrave on a Mazak vtc 200 c. I downloaded the trial but can not get good results. I am gettin A moves over 360 degrees. any help
    Oct 2007
    16
    Can you post a screen shot of the settings you are using?
    Chris W
    CNC Write Developer
    Feb 2009
    58
    Pic
    Here is the pic. I can do this very simple on my haas but machine time I have to use my Mazak. If I can get it working we can purchase the full version
    Feb 2009
    58
    one more note
    I didnt have the inverse time feed checked but tried both ways
    Oct 2007
    16
    The first problem I see is the Plunge Axis settings. The "Down" and "Up" values need to be relative to the the radius of the part you are engraving on. If the radius of the part is say .5 and you want to engrave .005 deep then "Down" would be .5 - .005 or .495. If You want a clearance over the part of .02 for rapid moves, then the "Up" should be .5 + .02 or .520.
    The software needs to know the radius it is engraving at and the "Up" and "Down" Plunge axis settings is how you tell it that. Hope that helps. There may be other issues but that is the one that I saw at first glance.
    Chris W
    Feb 2009
    58
    Simple
    ooohhhh. I new that it needed that but did not know where to tell it. Thanks a million.
    Feb 2009
    58
    I changed the Z depths. Still getting som crazy feeds . Do the Axis look correct for standard rotory setup? thanks
    Feb 2009
    58
    PIC
    Pic didnt load last post
    Aug 2006
    62
    You must have Axis1 set to X and Axis2 set to A and Plunge axis set to Z. This is if you have the A axis in line with X on the right end of the table. Your work offset for Y0.0 and Z0.0 must be in the center of the cylinder you are cutting on. You must use Inverse time feedrate. The code should be something like the sample below. Start with something simple like ABC.
    M1
    G40 G90
    T01T00M6
    G54 G40 G90
    S10000 M3
    G93(must have inverse time option)
    G00 Y0.0 M8
    (First Z move)
    (Engave)
    G91 G28 Z0.0 M5 M9
    M99
    Feb 2009
    58
    THANKS
    I can actually use the rotory on either side. I have one left and one right. I am going to use the right rotory. It is a disgrace to the Mazak but I have a HAAS 5c indexer mounted to a plate on the left side rotory to mill 10 slots on 15 deg for a product line. works good for a homemade 5th axis. I am going to try the engrave more
    Aug 2006
    62
    Let me know if it works.
    Feb 2009
    58
    love it
    I got to try the demo today and love it. great litte program will be purchaseing. are the owners of it on here
Page 1 of 2 12
  1. Replies: 11
    Last Post: 04-23-2014, 11:10 PM
  2. Engraving software
    By TheMadEtcher in forum Engraving Machines
    Last Post: 08-30-2010, 01:12 AM
  3. Engraving software
    By phatjap in forum Engraving Machines
    Last Post: 04-25-2010, 08:26 AM
  4. CNC Write Engraving software update
    By cdw3423 in forum News Announcements
    Last Post: 03-31-2008, 06:05 PM
  5. Engraving Software
    By The Wizard in forum Uncategorised CAM Discussion
    Last Post: 03-29-2005, 12:38 PM
