585,568 active members*
3,343 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > How good of a finish do you get on the TM series mills..
Page 1 of 2 12
Results 1 to 20 of 25
    Apr 2005
    903
    on aluminum?
    99.9% of what I machine is 6061. I can't really spend much more than what the TMs are going for and was curious what kind of finishes these machines get.
    I'm interested in feedback on any of the TM's, thanks.
    Jun 2006
    629
    On any machine, you need good cutting tools preferably solid carbide running as fast as possible speed wise, and feed will depend on the finish requirement.
    "It's only funny until some one get's hurt, and then it's just hilarious!!" Mike Patton - Faith No More Ricochet
    Apr 2005
    903
    I make after market paintball products. All stuff will be anodized, I would like to know how good of a finish you get with the lower RPM equipment like the TM's?
    Am I going to need to invest in finish equipment too?
    Jun 2006
    629
    No, It just takes longer brecause your feed rates will be lower.
    49
    The Physics Machine Shop here on campus just turned out a box that is incredibly smooth. I don't have the tools or knowledge to give you a hard number but is very impressive to my eye.
    Jun 2006
    629
    I worked at a place that did high end scientific digital camera bodies. We used Garr 242M series pretty much exclusively, and they worked well on 8,000 rpm machines and 15,000 rpm machines.
    Aug 2007
    135
    Tooling doesn't come into play in this question. The maximum obtainable surface finish is determined by the machine itself - especially in 6061, where you can use PCD and SPDT inserts. Obviously, a person needs to select the right tool for the job, but they are no longer the limiting factor in finishes.
    Again - surface finish is machine dependent and that's what the OP wants, not tooling suggestions.
    The Machinist's Chatroom
    http://machinechat.freehostia.com/
    Jun 2006
    629
    The question was can he get good finishes with this machine with a lower spindle speed.
    Besides if you say surface finish is entirely dependant on your machine you are WAY out to lunch. Compare surfaces from an HSS endmill and a SC Endmill compare finishes with the same tools @ different speeds and feeds. There are a lot of dynamics in the WHOLE system that will effect the surface finish that you can achieve. An endmill may want to shake rattle and role @ one speed, then settle down @ another. I've been around long enough to know that you can get a good finish on an old clunker, you just have to know how to caress it and sweet talk it.(nuts)
    YES - with proper cutting tools and speeds and feeds. Granted with a ؽ" endmill the spindle will be running full bore, but he won't be able to feed the same as say a 15K spindle machine.(nuts) If you were say gonna run the same parts on a machine with an R8 Spindle then I may say no.
    Oct 2006
    125
    how do you figure that tooling dosnt play a part. it plays a big part in time and money.
    with only 7.5hp and 4000-6000rpm coolant or no coolant. tooling could be the make or brake of a small shop in finish quality and time per part. the finish on a high helux tool will look a lot different than a insertable tool. and then you can go single or mutiple flute cutter. the limiting factors are hp and rpm, but they are only limits if you use the wrong tooling. the tm will be fine to do what you are looking at but you will want to look at the tm-1p with aluminum you will want coolant the open machine is fine but you will get very wet.
    Aug 2007
    135
    Quote Originally Posted by big_mak View Post
    Read the original post again. The title is "How good of a finish do you get on the TM series mills..", and goes on the specify aluminum in the body. He does not once mention spindle speed or tooling. He asked about a very specific series of machines, and what kind of surface finish are they capable of producing. A valid question for any precision engineer who has worked with surface finishing.
    It's such a common question in industries that require good surface finishes that virtually all high precision machine manufacturers will guarantee maximum surface finish right along with the accuracy, spindle speed, travels, and other machine parameters.
    I never said it's wholly dependent on the machine, there are other factors. But it's very easy to eliminate those factors, or make them an order of magnitude less important than the machine itself.
    Things like cutter material, edge sharpness, RPM, et cetera all affect the apparent asynchronous error motion of the machine. That's the fundamental mechanical property that determines surface finish, and nothing else. We could get into a whole discussion about what tooling to use, why, and what is going on at the molecular level that makes such tooling desirable. But that's not what the guy asked - he asked a very valid question about the machine he is considering purchasing. Fortunately for him, he's working in aluminum, and can use PCD inserts. PCD doesn't care how fast you spin it. You can run it at 2 SFM or 20k SFM, and you will get the same surface. So that he has an 8 rpm spindle on some machine won't matter, it will just be slow as piss. He will still get the best surface his machine is capable of producing.
    Machinists who have worked 30-40+ years in the industry usually have no clue why, again on a microscopic level, things like RPM affect the surface finish and how to eliminate RPM as a variable. They just know that RPM and tool material do affect the finish, and that faster is shinier.
    Jul 2005
    12177
    I think until you have a definition of 'good' in the question; How good of a finish do you get on the TM series mills.. you cannot answer the question. No matter what machine is used or what cutter is used at what speed and feed, the surface finish will vary depending on whether it is a surface that has been faced with the end of the cutter or a profile that has been finished withe side of the cutter. If it is desirable that the product have a uniform surface finish over all surfaces no matter what their orientation to the tool during machining, secondary finishing is probably going to be essential.
    Jun 2006
    629
    To quote Toasty "Tooling doesn't come into play in this question." says to me that tooling don't factor into the equation. If you didn't mean that, then you should think a little harder before you answer.
    Aluminum is fickle, and one person's good finish is not acceptable to some one else. MAYbe LUKE can clarify for us what a good finish is. say 125 microinch or is he looking for 16 micro inch. I've done camera's where no machining marks were acceptable period. We have 16 finishes on them, then they got tumbled in walnut shells.
    As for PCD inserts in 6061, it may work for you, but it won't work for everyone. Why spend $40 an insert when I can get the same results with Carbide for less than half the price.
    Oh look we have a problem! let's throw some $$$$$$ and it will all be better!!!!!
    when you talk of maximum finishes, these machines have been tested bolted to the optimum foudation isolated from any extraneous vibrations, with a solid hunk of material clamped to the machine table that ain't going now where's!!!! In the real world I'd say that most machines aren't mounted to the ideal foundation, and are not isolated from vibration from outside sources, so the manufactureres spec is almost never really achieveable aspiclaly when the dude in the test lab has the time to dial in the tips of his trusty PCD sutter with wipers to the nearest micron. Who in the REAL world has this time, let alone patience.
    Paintball parts + TM mill = acceptable results
    Apr 2005
    903
    Good = a finish that will not need to be polished before going to anodizing. Most all high end paintball products do not have tooling marks that are visible (to the human eye) after anodizing. I'm after a machine that is capable of producing that type of finish.
    I understand that tooling, cutting speeds, coolant, fixtures, etc are factors, but those things are all adjustable after the machine are purchased.
    There is still good information to be gleaned from the misunderstanding of the original question. All view points are valid and are helpful.
    Jul 2005
    12177
    Quote Originally Posted by l u k e View Post
    Good = a finish that will not need to be polished before going to anodizing. Most all high end paintball products do not have tooling marks that are visible (to the human eye) after anodizing. I'm after a machine that is capable of producing that type of finish. .....Thanks
    It is called a Vibratory Polisher, and I am not being a smartass, you will not get a polished surface all over from any milling or turning operation unless you are making optical parts under special conditions.
    The influence your milling machine will have is how long the parts have to stay in the polisher and whether it will need a change of media to take down surface roughness first then impart a polish.
    Feb 2008
    11
    I think you will be able to achieve the finish you need.I also do aluminum and anodize my parts ,and I still get everything polished before anodizing them it looks so much nicer .I use someone out of state to polish them,because the price I pay to ship and polish,I will never need to buy finishing equipment.But in my opinion you can achieve the finish you need on the TM series,I dont own one but I achieve A good enough finish for retail using A retro prototrak in the early days,not knocking that machine I love it,I just installed the retro on A good old used Bridgeport.Thanks Chris
    May 2007
    781
    Safe bet you will not get the type of finish you could get on the likes of a Yasda.
    Have to sell a lot oh paintball guns to pay for one of those.
    Jul 2005
    12177
    Here is a thread about surface finish, I put a picture in Post #8 showing the finish off the machine from a Haas MiniMill. It is likely that the TM series would be very close to this. It is possible to see tool marks and these are visible after anodizing. It is also possible to see that the finish is different in different areas.
    http://www.cnczone.com/forums/showthread.php?t=39855
    Apr 2005
    903
    Thanks for all the info.
    Oct 2006
    125
    one more thing to throw in the pot your surface finish will also depend on a good g code software. i know that the finish i get for my lest expensive program to my more expencive is day and night .more options in cuts less segmants better arc control etc. you wont need high speed but a good cam program will make a big difference in part finish.
    Apr 2005
    105
    Luke. You can get a good or great finish off of a TM machine it all about the tooling and the way you machine the part. Just it might take a little more thought on tooling to achieve your requirements because of the machine limitations (low rpms, not flood coolant, ect...)
Page 1 of 2 12
  1. Getting a good finish turning copper
    By Warpspeed in forum MetalWork Discussion
    Last Post: 07-21-2007, 09:57 PM
  2. Face Mills? Which one to choose for a good finish on aluminum?
    By peter.blais in forum Uncategorised MetalWorking Machines
    Last Post: 08-25-2006, 04:41 PM
  3. Good plastic Finish
    By Smackre in forum Glass, Plastic and Stone
    Last Post: 06-06-2006, 07:46 AM
  4. Ceramic Mold vs Good Finish
    By ckrantz in forum Moldmaking
    Last Post: 11-01-2005, 05:18 PM
