Hi Tommy,
Yes, my Nook ballscrew arrived within a few days of placing the order.
It is a .631 dia, .200 lead. 48 inches long.
Here's the link:
Nook .631-.200 ballscrew
Haven't had a chance to play with it yet. I'll probably save it for my next (larger) router.
Originally Posted by
~TM~
I'm still trying to decide on my lead screws. Either 1/2" 10 5start with dumpster nuts and pillow/flange bearings or a ballscrew from Reid. ANY suggestions would be appreciated : ) Which would have better accuracy.
The Reid rolled ballscrew's lead tolerance is +-.004 per foot.
Reid precision acme threaded rod (single start) is rated at +-.003 per foot.
I don't know the specs on the multiple start acme rod, but I doubt that it will be as accurate as the precision acme or rolled ballscrew.
~TM~
One more question...would i be ok to use an unsupported 30mm hardened shaft (the picture above) as the gantry axis.
I would try it unsupported BUT give myself the option of installing full supports later if necessary. It would be interesting to measure the difference in rigidity...
Diplomacy is the art of saying "Nice doggie" until you can find a rock. - Will Rogers
