585,974 active members*
4,084 visitors online*
Results 1 to 13 of 13
    103
    Taig coolant tray
    I’ve recently acquired a Taig CNC ready mill and lathe.
    As I wait for the electronic components, I have made plastic coolant trays for flood or mist coolant. Photos are located in the SteveM photo album.
    A few spares were made for evaluation and I am prepared to sell these prototypes, for the cost of the plastic, to Taig mill users in the Toronto area, in exchange for an objective critique.
    These may be available for purchase if there is demand.
    Pics are here: http://ph.groups.yahoo.com/group/tai...os/browse/fd60
    Steve
    Sep 2006
    1738
    Your pictures don't work! And I don't want too sign in and register! Another source???
    -Jason
    103
    Here you go.
    Sep 2006
    1738
    Daw Kewl
    Very similar too mine, except smaller. Cool though.
    -Speed
    Feb 2007
    64
    tsalaf where are you located?
    where did you get your mill/lathe?
    nice tray
    103
    I'm in Thornhill, ON and purchased the machines from Taig.
    Nov 2007
    980
    Nice tray but noticed that it looks like if the table is all the way to either side, the coolant would drip over the edges of the tray, no?
    Dave->..
    103
    The tray is sized to fit inside the box that Taig uses to ship the mills.
    Since my mill is not running yet, the drip from the end of the table
    did not occur to me. I will have to address this problem while still
    keeping the overall size of the tray the same.
    Sep 2006
    1738
    Also, what about when actually milling and using fluid, what about spray and everything?
    -Jason
    Feb 2011
    Here is a coolant tray I designed and had made. Interested? I can have it customized for your machine. The unique thing is the upper left and right sides make it easy to run large work, there are windows in each side to make it easy to run longer tubes.
    Feb 2008
    194
    Quote Originally Posted by tsalaf View Post
    I tried with smaller trays and gave up. The smallest that worked for me is a 24x36" tray. The machine sits above the tray inside of inside of it and I used plastic sheeting to make "shower curtains" that go around the machine and direct coolant into the tray. The tray is tilted at an angle towards the drain.
    There is a not very good photo here:
    CNC Taig Mill - AlexAndChristine's Photos | SmugMug
    My machine is slightly disassembled at the moment, but when I get it back together I will take better photos.
    Jul 2006
    17
    ...I have made plastic coolant trays for flood or mist coolant. ...
    Steve - Just curious... How did you make these? -Keith
    Nov 2009
    42
    Cheap Colant Tray
    I did a REALLY cheap coolant tray from scrap melamine (ply or chip board would be fine) with 3" walls on 4 sides. Ply platform about 1 1/2" thick to lold mill. Piece of masonite with cutout for platform mounted inside tray to slope forward (did not have this on first version so coolant just puddled). Cut hole at front for bit of copper pipe (well sealed with caulk) to feed coolant to pvc pipe. Lined the whole thing with 2 layers of kitchen shelf liner, plastic sticky one side.
    Spray is collected with clear plastic curtain (sold in fabric stores to protect tablecloths) hanging with shower curtain hooks from plastic electric conduit so it ends up inside the walls of the tray.
    Just close the curtain and go.
    Ugly, cheap but works.
  1. Table tray for coolant/swarf protection....
    By InspirationTool in forum Benchtop Machines
    Last Post: 02-12-2011, 04:35 PM
  2. Coolant tray for X3
    By oldtool in forum Polls
    Last Post: 02-10-2011, 06:11 PM
  3. My Taig CNC and Coolant~Video~
    By CROSSHATCH in forum Taig Mills / Lathes
    Last Post: 01-25-2008, 11:08 PM
  4. What Coolant For Taig
    By DroopyPawn in forum Taig Mills / Lathes
    Last Post: 11-21-2007, 12:47 AM
  5. Taig Mill: Coolant recycle...
    By kinneycan in forum MetalWork Discussion
    Last Post: 11-02-2005, 07:24 PM
