585,982 active members*
4,688 visitors online*
IndustryArena Forum > MetalWorking Machines > Syil Products > Syil Controller - probe input?
    Feb 2008
    154
    Does the Syil controller have a probe input capability to work with touch probes like this one?
    http://www.cadcamcadcam.com/index.as...PROD&ProdID=10
    May 2006
    1469
    Yes you have five inputs. 10 to 13 and 15
    Use any of these if not already in use. I use 11
    Greg
    Feb 2008
    33
    There is one free input, it is the connector next to the estop. This input is also connected to the A reference so you can use that connector also. The pin for that input is 11, as Greg mentioned.
    Based on the description of that probe you should have no problem hooking it up. Connect one lead to the signal input (pin 2) and the other to ground (pin 3).
    Feb 2008
    154
    I stumbled across this touch probe made and sold by a fellow over on the Mach forums http://www.machsupport.com/forum/ind...ic,5004.0.html
    I've bought this one and one of his camera setups
    http://www.machsupport.com/forum/ind...ic,2519.0.html
    and I don't even have my Mill yet
    Feb 2008
    33
    Hey that's a good deal for a probe! I just ordered one, thanks for the link.
  1. Syil X2 cnc controller or PC interface problem
    By tbilalis in forum Syil Products
    Last Post: 06-19-2007, 12:11 PM
  2. Syil Controller Question
    By mayhugh1 in forum Syil Products
    Last Post: 02-06-2007, 08:39 PM
  3. Super X3 spindle controller (by Syil)
    By ints99 in forum Syil Products
    Last Post: 12-10-2006, 11:35 AM
  4. My Controller purchase (Last chance for input)
    By Rance in forum DIY CNC Router Table Machines
    Last Post: 10-11-2006, 11:25 PM
  5. Controller Input/?
    By Ken_Shea in forum OneCNC
    Last Post: 06-01-2003, 02:57 AM
