585,982 active members*
4,549 visitors online*
Thread: cnc grinding
    Mar 2007
    14
    Post cnc grinding
    Is there anyone out there trying to grind on a cnc mill? I'm experimenting with 2" dia type W mounted points held in a collet and attempting to grind a cylindrical boss. My tolerance on a 3" diameter boss, 3" long, is +/-.0005 diameter with a 32 or better finish.
    Mar 2006
    2712
    Without really "fine tuning" I doubt a typical vertical mill will reliably hold .0005" tolerance. Is there a roundness tolerance?
    Can you build up the rpm for grinding? It may be possible to do so with a "speeder" or jig grinder attachment.
    What about grit messing up the way surfaces? Could be somehow protected, I 'spose. I know we used to grind on lathes with toolpost grinders, but what a mess!! Oil soaked rags wrapped over exposed surfaces to catch grit etc.
    Is it possible to use single layer plated wheels? Probably that would require an elaborate coolant system.
    The short answer? Probably can be done, but I wouldn't do it. You didn't give much to go on as far as specifications (material etc. and complete tolerances). I'd find a jig grinding source if precision is required.
    Dick Z
    add: check this out http://www.vulcancut.com/vulcanaire.html
    DZASTR
  1. Grinding
    By krismcneil in forum MetalWork Discussion
    Last Post: 05-03-2007, 02:06 AM
  2. Grinding how to..
    By JerryFlyGuy in forum MetalWork Discussion
    Last Post: 01-19-2007, 05:40 AM
  3. Grinding
    By itsme in forum MetalWork Discussion
    Last Post: 07-23-2005, 08:21 AM
