585,973 active members*
4,201 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Using the touch-off probe in a Johnford Lathe 650A.
    Feb 2008
    10
    Hello,
    I want to use the touch-off probe in a Johnford Lathe 650A; but I have not figure out how to activate it (I don't have the manual). Somebody can help me with this?
    Thank you very much.
    Nov 2006
    12
    not sure if this will work but we have a bt-40 lathe and heres how we do it. select your tool needed to touch off, go to the offset screen, next(I think its the + screen key) then press the OPR screen key there should be a list of options here that allow you to turn on the post. and should auto matically take you to the geometry screen for tool lengthnote that you only need to turn it on after lowering post. handwheel tool close to stylus then go to jog mode and use axis direction buttons to feed into stylus when tool is touched off light should turn red
  1. touch probe and Mach3
    By devincox in forum Mach Mill
    Last Post: 02-16-2010, 03:58 AM
  2. k2CNC 3D Touch Probe
    By Mike Stevenson in forum K2CNC
    Last Post: 02-14-2008, 07:44 PM
  3. Touch probe for sale
    By cut more in forum Digitizing and Laser Digitizing
    Last Post: 03-08-2007, 12:50 PM
  4. Touch Probe for a Noob.
    By lilricky2 in forum Digitizing and Laser Digitizing
    Last Post: 02-02-2006, 11:04 PM
