585,727 active members*
4,008 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Ball Screw or Lead Screw? Which is Better?
    Oct 2003
    208
    On about 46" of length which is better lead screw or ball screw?
    Also what diameter would be best?
    Right now I have 1/2" dia acme screw and it whips alot at 75 ipm.
    Could someone list the pros and cons of each?
    Is your acme 1/2-10? if so, you might want to try 2 start 1/2-10, which would only turn half as fast. It will also only have 1/2 the torque, though.
    If you're trying to eliminate the whipping, a ball screw or an acme with the same lead should'nt be much different. A ball screw is more efficient, though. But, you'll need to keep the dust from getting into the ball nut or you could have problems with it.
    Oct 2003
    208
    It is 1/2 - 10 with 1 start.
    Mainly I was wanting to know which type of screw is stiffer.
    Maybe a ballscrew a little, but not much. go to http://www.nookind.com and check out their catalogs. they have charts showing the max speed you can spin the screws before whipping occurs (critical speed).
    May 2004
    37
    leadsrew size
    To all,
    I am designing a router with an effective working surface of the size of an A3 paper (2 x A4) and I do not know what size screw i have to take.
    I find that there are many different "acme" (tapezium) screw types and sizes.
    What leadscrew is needed?
    If one has the oportunity to use a screw of tr10-2 oposed to tr14-2 and tr16-2
    What would be the best choise?
    Willy
  1. Lead screw whip
    By spalm in forum DIY CNC Router Table Machines
    Last Post: 05-24-2005, 08:04 PM
  2. Upgrade to a 1 inch ball screw with a .5 lead...???
    By bgolash in forum DIY CNC Router Table Machines
    Last Post: 01-25-2005, 03:37 PM
  3. Compensating for ball screw lead error?
    By Noah in forum Uncategorised MetalWorking Machines
    Last Post: 08-13-2004, 02:51 AM
  4. ball screw lead amount
    By replicapro in forum Uncategorised MetalWorking Machines
    Last Post: 07-03-2004, 01:59 PM
  5. Ball Screw and Lead Screw
    By ljoe1969 in forum DIY CNC Router Table Machines
    Last Post: 11-21-2003, 03:06 PM
