585,581 active members*
3,887 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > Open Source Controller Boards > Open Source Boards Available, Stepper Drivers and Break Out Boards
Page 14 of 39 4121314151624
Results 261 to 280 of 763
  1. #261
    Feb 2004
    466
    I got it.
    I believe that the schematic of the chopper board has incorrect labels for the X2-1 and X2-2 connector, they're swapped.
    X2-1 should be positive and X2-2 should be negative.
    The first time I hooked the PSU my led didnt lid, so I thought "Oh well , I always get confused with the leds" and I resolder it so it lid, but the problem was another.
    Correct me if I am wrong.
    Konstantin.
  2. #262
    Feb 2004
    466
    Well I have hooked the PSU correctly to the chopper.
    The motors spin allright, aparently.
    There have been some jerking in one of the motors, maybe TurboCNC settings might need adjustment. Max speed 1000 for now, latency 33.
    I am using 3n3 on the chopper, IRF9540 get HOT. Not all the same as hot.
    The zenners not very hot, just one of them. The resistors do not get as hot as with the PSU wrongly connected. I wonder if the chopper board suffered any damage because I ran it with the wrong polarity?
    The discrete unipolar drivers are not even warm.
    One thing still puzzles me. My motors are 5.2v and my PSU is 25. The chopper will limit the current amount accordingly to the resistors I used and the cap, right?
    But what about the voltage? The voltage on my motors will be 25, correct? Is that allright for the motors? They were a bit warm that's it.
    Konstantin.
  3. #263
    Apr 2004
    169
    I'll have to check the supply connections later. It's very unlikely any damage was done by the reverse polarity. Sounds like some heatsinks are needed on the 9540's try a small shaped piece of aluminum even a bit from a can should work ok.
    A simplification is to think of the chopper supplying small pulses of voltage so the average voltage is correct. But really steppers are current operated devices. So what we need to do is forget about the voltage rating and just supply the correct current.
    Good to hear it's working in any case.
  4. #264
    Apr 2004
    209
    You should check out the SLA7024M/SLA7026 "1.5amps/3amps constant" uni polar stepper drivers! they have built in choppers which is controled by a pentiometer, and they operate by by 4 ttl inputs for each step. they run upto 36v/ X amps.
    http://smba.kpc.ac.kr/admin/bbs/data/Drive/SLA7024.pdf
    This i what I'm going to base my controller on, and I have a friend working on building a stepping controller out of a 16f877 which with ANY luck will include a step buffer so there will be no problems with windows jerkyness in running stepping motors straight from the par-port.
    a few other features he's working on will be a hardware step limate so the controller its self will not let the machine advance past the limate switches +/-. an other feature he's hopping to add will be a hardware level max pulse rate with ramping. which would also be adjustable because this pic chip has software editable eeprom. there are more things I could write but I'll wait for an other time, I also give it about 2 months tops for a beta to be out. This will be a very compact modular design. for now dual 16f84's with the public asm step/dir driver kit from the turbocnc page are my step/dir to phase controllers.
  5. #265
    Jun 2003
    3312
    Berin,
    While the 7026 is a nice looking part, at over $10 apiece and no stock anyplace I'm not sure it's good to base anyting on just yet. What benefit is there over the L297/298 or a3977 and running bipolar?
    Phil
  6. #266
    Jun 2003
    3312
    Konstatin,
    On the interface board, LED2 needs to be removed and jumpered for Estop to work correctly. I updated the Document for it.
    Phil
  7. #267
    Aug 2004
    170
    This Allegro 7026 simply doesn´t exist heare in BRAZIL, i´ve searched. If someone have other idea, let me know too.
  8. #268
    Apr 2004
    209
    well for starters very simple basic design circuit wise, onboard variable chopper controller. If you cant find them to purchase they are in all kinds of devices. Mainly BIG!! printers and photo copyers and photo machines period! They are in almost every old dotmatrix printer. and I'm not talking about the little okidata. I'm talking about the big two foot wide printers. There is an electronics salvage place near me which I raid every now and then. next time I go threw if I pick up a bounch of these chopper phase driver chips I'll post that I have some available.
  9. #269
    Jun 2003
    3312
    4 Axis interface board now available: http://webpages.charter.net/pminmo/cncelectronics.htm
    Phil
  10. #270
    Aug 2004
    170
    Sorry, Master, I didn´t understood, it´s a 3axis and a 1axis, or a 4axis ? and where can i get a 1axis and a LPT-PCB-adapter ?
    Hey, thanks a lot! Because you i will make my own CNC !!!! Maybe a new future!
  11. #271
    Aug 2004
    170
    OH, sorry again, i got it NOW !!! I´m a bad listener !!! hahhaha
  12. #272
    Jun 2003
    3312
    Ito,
    There are many different boards, and lots of ways you can configure.
    Phil
  13. #273
    Jun 2003
    3312
    Ito here are two pictures to help explain.
    Picture 1 is the three axis INTERFACE board. On the left side is a db25 connector that via a cable hooks to a pc's parallel port. The three 10pin cables on the left go to 3 single axis stepper driver boards as pictured in the 2nd picture. (the top one is non funtional, just convienient for picture) The driver boards pictured are based on Allegro's a3977 chip to driver bipolar steppers rated up to 35V and 2.5 amps. If you want to drive one of the steppers as unipolar, then you can use one of the 5804 or discrete unipolar designs. The driver boards in this example can all three be the same or two the same and one different or all three different. i.e. mix to your needs.
    The 3 axis board of Tachus42's is one board not four as shown in the picture. It has three axis of unipolar drivers plus the connection to the computer parallel port.
    Phil
  14. #274
    Sep 2004
    7
    Sorry for my English. But Allegro chip has 2.5 A current limit.All steper drivers have a current limit 3 A.But stepper motors have 6 A current.What feed it motor?
  15. #275
    Sep 2004
    7
    Sorry. What does feed it motor?
  16. #276
    Sep 2004
    6
    Hi tachus
    I got a few newbie questions, can i use IRL530 insted of IRLZ44 FETs as they are really expensive here in Denmark and can i use ECM265M-E1.0A steppers with the 3 Channel Discrete Unipolar Board and howto wire them.
    ECM265M-E1.0A Datasheet -> http://www.ec-motion.de/pdl/ECM265M_d.pdf
    Regards
    Michael - Denmark.
  17. #277
    Aug 2004
    170
    Hey, Master Phil:
    THANKS A LOT! Now i´m close to understand the electronics of a CNC.
    AND NOW I BELIEVE THAT I CAN DO IT !!!!
    hey, NEWBIES, unite ! Let´s learn together!
    Thanks again PHIL. PHIL IS OUR KING !!!!!
  18. #278
    Aug 2004
    170
    I have the same problem: my motors have this specs:
    Current: 3.1A ;
    Volt: 2.6 V
    May I use the 5804 based PCB ?
    Sorry the "abuse"...
  19. #279
    Apr 2004
    169
    Cossie
    IRL530s will be ok for your motors. You could use a 12 volt supply and 6.8 ohm current limiting resistors as a starting point. The winding connections are shown on the datasheet. Connect the Wires with a white stripe together for each phase to make the common.
  20. #280
    Sep 2004
    6
    Quote Originally Posted by tachus42
    Cossie
    Thanks tachus for you help..
    btw, are those steppers any good for an CNC ??
    Regards
    Michael - Denmark.
  1. Best break out boards?
    By Nigel Tufnel in forum Stepper Motors / Drives
    Last Post: 12-27-2013, 07:12 PM
  2. Dual Break out boards
    By ynnek in forum DIY CNC Router Table Machines
    Last Post: 07-11-2013, 04:34 PM
  3. Break out boards...
    By kiwichris in forum LinuxCNC (formerly EMC2)
    Last Post: 11-06-2012, 10:20 PM
  4. Servos, drivers, break out boards
    By HereinCS in forum Servo Motors / Drives
    Last Post: 08-13-2010, 06:09 PM
  5. PC parallel port break-out boards
    By widgitmaster in forum CNC Machine Related Electronics
    Last Post: 09-20-2005, 01:47 PM
