Currently we have a Faro arm and are looking to improve our inspection methods . We are using faro's cam2 v4.0 and are not having luck with comparing solids from our Engineering department against the parts. What is the current industry standard when it comes to CMM software package? Ideally we can import solidedge v20 files directly select a feature on the model and using the faro arm touch off the part to compare dimensions. This is taking place in a Job shop so while there will be multiple parts measured from each model we would like to avoid any long prep times for the models. (Ex. creating a unique inspection profile for every part to be inspected) Any input is welcome, Thanks
