586,024 active members*
4,176 visitors online*
IndustryArena Forum > MetalWorking Machines > Hyundai Kia > Hyundai Quickturn 8N Control Help
    Mar 2008
    Exclamation Hyundai Quickturn 8N Control Help
    We have a Hyunday Quickturn 8N lathe that has a Mazatrol T32b control on it. We cannot figure out how to pull the programs off of it as well as push new ones up. Does anyone have any advice for me on software as well as the correct buttons to push on the control? We have a RS232 cable that i believe is the correct configuration but if someone had that info I could verify...
    As you can guess...right now the only way to get a program on the machine is to type it in! UGGG
    Ryan
    Aug 2006
    21
    Hello Hawkeye,
    I found this site http://www.productionshopadvisor.com/Downloads.htm, they have a manual available for the Mazatrol T32b control.
    I have not used this control so I'm not able to help with up load / down load on this unit.
    As for the RS-232, that's pretty easy. Google RS232 and get the pin out. Here is a site for that: http://www.lammertbies.nl/comm/cable/RS-232.html#pins
    Verify your cable pin out and you will be good on that. As far as the settings go, that depends on the machine control and parameters which control things like baud rate, parity and flow control. I just went through all of this on our Hyundai with Yasnac J50M control. I use EZ DNC software for the upload / download form my PC. I took a stab at the settings as I didn't have a manual and lucked out through trail and error.
    Our machine was set to use 4800 baud, 7 data bits, 2 stop bits and even parity. Also, the programs need to have a "%" sign (percent sign) at the very top of the file and the very bottom of the file, this tells the control where the file begins and ends. This could be different on your machine, but I think this is pretty common. Make sure to have the program number ( I.E. O2222 ) as the first line in the program (not counting the required % sign) and you will be good.
    Good Luck!
    Kevin
    Sep 2007
    5
    You might look for "Griffo Brothers" software for mazak
    to send back and forth
  1. hyundai hit 8
    By drill in forum MetalWork Discussion
    Last Post: 09-10-2012, 01:17 AM
  2. Hyundai VMC
    By kevinkoons in forum Hyundai Kia
    Last Post: 03-30-2009, 06:27 PM
  3. Thread blunting on cnc hyundai w/ seimans control
    By nowwhat in forum Community Club House
    Last Post: 07-02-2006, 12:13 AM
  4. Thread blunting on cnc hyundai w/ seimans control
    Last Post: 06-29-2006, 07:52 PM
  5. mazak t32-2, quickturn 8n
    By Enda in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-09-2006, 11:00 PM
