585,668 active members*
4,092 visitors online*
Results 1 to 10 of 10
    Mar 2008
    Mazatrol T32 File Transfer Software
    Looking for a file transfer software for upload/download from a Mazatrol T32 primariliy, but also want to communicate with a Acramatic 850SX, Siemens 810T, Fanuc OT, and AB 8600.
    Currently have ProComm (DOS version) to communicate with a most controls, but I need to get a software to upload/download from the Mazatrol.
    Ideally was looking for a software to communicate with the Mazatrol and some or all of the above controllers and eliminate the need for the old DOS ProComm.
    I see Griffo Brothers is primarily for Mazatrol, but does anyone use it as a universal software. Others I am looking at are WinDNC (Greco) and PCDNC (Suburban). I believe they are suppose to be able to commucate with all including the Mazatrol, but wondered if there would be limitations.
    Any suggestions from any users with similar situations welcome.
    Primary function is for file backup.
    Mar 2005
    988
    It's just a part..... cutter still goes round and round....
    Dec 2006
    5
    The only software that we could get to work other than the ridiculously expensive Camware was MultiDNC. You can normally download a trial version from their site www.Multi-DNC.com
    The only problem is that it downloads in hex and cannot be read very easily. (Unless you can decipher hex) You can still send it back to the control without a problem.
    The Multi-DNC cam communicate in CMT format as well as ISO/ASCII.
    Remember to plug your cable into the controls Microdisk port and if the machine has the EIA option, plug the cable into the printer port which is normally mounted next to it. You will be able to edit and read the EIA format.
    Dec 2006
    5
    Me again, the microdisk port is used for the CMT format and the printer port for the EIA/ASCII format(G codes & M codes)
    Feb 2008
    7
    We have used Griffo Bro. for all our machines (Mazak & others) for many years now and it works great.
    Feb 2008
    25
    Smile
    Hi
    I just got Griffo and it works ok with my Mazak and my Deckel (siemens 3m)
    Vladimir
    Jul 2016
    108
    Re: Mazatrol T32 File Transfer Software
    here you are
    Attached Files Attached Files
    Jan 2021
    Alguien tendra el software Mazak Data Transfer (MDT32) para un control mazak T-plus
    Saludos
    Oct 2022
    Lo pudiste conseguir? El programa es bastante escaso al parecer.
    Oct 2022
    Ya lo conseguiste? Lo tengo a la venta.
  1. Mazatrol/EIA file transfer
    By bz1801 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-04-2017, 12:15 PM
  2. Free DNC RS232 software for serial file transfer
    By bborb in forum DNC Problems and Solutions
    Last Post: 10-11-2016, 02:18 PM
  3. Free Large File Transfer Software
    By angelstar in forum OpenSource Software
    Last Post: 04-26-2008, 10:10 AM
  4. Transfer file from Mazatrol L32B to Computer
    By ArcticMetal in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-25-2008, 11:21 AM
  5. Mazatrol T Plus file transfer
    By ict in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-23-2008, 04:28 AM
