585,700 active members*
3,317 visitors online*
Results 1 to 11 of 11
    Jul 2004
    7
    How to hold small workpiece?
    I have to mill few hundred of small blocks out of ABS sheet using 2D prog. Part is fairly simple and size is about 6mm cube having little corner radius. I'm trying to machine multi-pieces right thru out of a large sheet but problem is part moves and gets damaged at the end of the cut because no clamping left. Could someone advise the best strategy to machine without damaging the parts. Thanks in advance.
    Kevin
    Feb 2004
    16
    tabbing
    Try using tabs, rout thru in some ares and not others and clean them up by hand. make tabs as thin as you can and you may be able to snap them off clean
    Jul 2004
    7
    I thought so but visual appearnace on the part surface is very important and part itself is so small that not much left for routing once I leave some tabs on.
    Feb 2004
    16
    tabs
    How about 2 passes do tabs on the first pass, than cut tabs on the second pass. and also you might try contact cement. Are you using a down shear cutter I find that helps hold parts in place
    May 2004
    83
    Heres a way I've done some thin sheet aluminum parts in the past. mill the profile, leaving the entire bottom of the slot intact but just a few thousandths thick. then drop down thru the part and cut it free with the exception of a small tab midway on each side. When you remove the sheet, you can turn it over and cut the parts free of the tabs with an exacto knife. Having the tabs NOT at corners makes this fairly easy.
    Nov 2003
    634
    Some more options:
    1. Leave about .002 material and run the blank through a sander (Performax drum sander) to seperate the parts from the blank.
    2. Use carpet tape to hold down the sheet, cut normally, then pull the parts off of the carpet tape.
    T
    507
    I have seen it done like Metlmuncher says, it works! Otherwise it can be stacked and cut with a wire-edm.
    Klox
    *** KloX ***
    I'm lazy, I'm only "sparking" when the EDM is running....
    May 2003
    340
    I like buscht's 1st suggestion. You could do that in a mill, possibly adding extra clamping in the form of wax so the parts don't fly off.
    Klox, edm ABS? That's a new trick
    Apr 2003
    3578
    I like buscht's #2 suggestion. I have done this dons of times.
    use 3m doulbe sided tape.
    Use to do this for samll inserts for wax investment molds.
    Cadcam
    Jun 2003
    2103
    Quote Originally Posted by Klox
    Klox
    Klox can you edm plastic? I am probably showing my ignorance here but I have plenty of it to go around. :tired: I though ABS was a type of plastic and if it isn't be gentle when you tell me.
    Mike
    No greater love can a man have than this, that he give his life for a friend.
    507
    Hey guys, sorry i read this thread while wearing my welding helmet! LOL! No you can't edm plastic!
    My humble apologies........
    Klox
    *** KloX ***
  1. Vacuum Hold down for wood.
    By HomeCNC in forum DIY CNC Router Table Machines
    Last Post: 06-08-2014, 03:29 PM
  2. How to Run a Large Stepper On A Small Board without frying
    By Sanghera in forum CNC Machine Related Electronics
    Last Post: 04-27-2004, 11:39 PM
  3. How does a servo hold its position?
    By ynneb in forum CNC Machine Related Electronics
    Last Post: 03-08-2004, 04:10 PM
  4. How do you hold stuff down?
    By samualt in forum DIY CNC Router Table Machines
    Last Post: 11-14-2003, 06:24 PM
