586,009 active members*
4,659 visitors online*
Results 1 to 7 of 7
    Sep 2006
    17
    USB to Parallel port?
    Is there a usb-parallel adapter available that will work for the hobbycnc 4 axis kit?
    Thanks..
    35538
    No, but you can use an ncPod or SmoothStepper with Mach3 with your HobbyCNC. The ncPod is about $100 and the SmoothStepper is $155
    Sep 2006
    17
    Thanks Gerry. Do you have a link where I could read more about them and purchase one?
    Thanks again..
    duder
    35538
    Sep 2006
    17
    So to install the ncpod board, the connection is as simple as,
    out of my laptop with usb.
    - into the usb ncpod board.
    - out of the ncpod board hardwired Rs232 parallel cable.
    - into my hobbycnc 4 axis board.
    - hardwire out of the hobbycnc board to my steppers?
    Correct?
    Thanks for your help!
    Steve
    35538
    I think that's it.
    Aug 2006
    45
    want to know what's cheaper than all of these options?... a really cheap used PC from eBay. Could set up a specific computer to run the machine, add a wireless networking card to transfer the jobs and come in under $100. I bought a used 1ghz machine (should be more than enough) for less than $50 delivered. don't even need an extra monitor... use a monitor only for setup, then use VNC to watch the system from your lappy or wherever across the network. This way you could have a nice comfy office, and through VNC be seeing what the machine's doing. Thinking that I'll be going this way rather than fussing over USB's and docking stations for laptops.
    http://www.realvnc.com
  1. C++, Win XP, Parallel Port
    By Zumba in forum Coding
    Last Post: 03-29-2012, 07:12 PM
  2. 2nd PCI Parallel Port
    By sunmix in forum Mach Software (ArtSoft software)
    Last Post: 11-22-2006, 09:17 PM
  3. Second parallel port?
    By essa in forum LinuxCNC (formerly EMC2)
    Last Post: 04-12-2006, 08:18 AM
  4. Parallel port
    By Aldoseri in forum BobCad-Cam
    Last Post: 03-13-2006, 05:10 PM
  5. Parallel Port
    By Shanghyd in forum Computers / Desktops / Networking
    Last Post: 11-22-2004, 06:56 PM
