585,975 active members*
4,630 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Info on formula to determine specific cutting force (kc)
    Feb 2007
    Could any one tell me formula you use to determine specific cutting force. Current Sandvik catalog doesn't include formula or example of using it. Am curious if in current catalog I multiply value by 250% if I'm taking a .04 chip as opposed to .016. Seems logical. Would think formula is in older catalog.
    Oct 2010
    21
    ks=ks11*h^(-z)*k(alfa)*k(tool)
    you need more coefficient to calculate ks
    k(alfa)=c-1.5*chip angle of tool/100
    k(tool)=stell=109
    h=chip thickness
    h=(360/3,14*Q)*(a/D)*Sz*SinX
    Q=Cutting angle
    a=depth of cut
    D=tool diameter
    Sz=feed rate for 1 teeth
    X=90 for endmilling
    CosQ=(D/2)-a/(D/2)
    Re: Info on formula to determine specific cutting force (kc)
    Hello
    This is what i found.
    Ap = Axial depth of cut
    Ae = Radial Depth of cut stepover
    Vf = Table Feed
    Kc = the specific cutting force value (kc) is a material constant
    __________________________________________________ ________________
    formula
    HP=(Ap*Ae*Vf *Kc) / (10³ *396)
    HP 8.34 = (0.75*.05*200*440,800) / (1000*396)
    I need help learning the (KC)
    (1) Where do i find this value?
    (2) How can i calculate from
    • Rockwell
    • Tensile Strength
    • Other
    Geoff Hicks
  1. Formula to calculate the force on the tip of an insert.
    By bruiron in forum Uncategorised MetalWorking Machines
    Last Post: 10-25-2012, 05:29 PM
  2. problems with cutting my part in a specific location
    By williamsmotower in forum MadCAM
    Last Post: 03-13-2012, 06:46 PM
  3. Collet Gripping Force Formula
    By JMS4287 in forum Mechanical Calculations/Engineering Design
    Last Post: 02-27-2012, 03:25 PM
  4. Specific Picture of Big Laser Cutting Machine
    By kofi_sunic in forum News Announcements
    Last Post: 11-10-2011, 07:00 AM
  5. Cutting forces at bearings? How to determine?
    By Noodles87 in forum Mechanical Calculations/Engineering Design
    Last Post: 04-25-2008, 10:04 PM
