585,752 active members*
4,105 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > To Ground or not to Ground That is the question!
    Sep 2003
    1469
    Question To Ground or not to Ground That is the question!
    The frame of my CNC is made of MDF and I was wondering if I should run a ground wire to my motor bases, linerar bearings and the metal portions of the machine?
    24220
    That is one problem with a MDF constructed machine, personally I would bond all metal parts together, and connect to a common ground plate.
    I use this method in general and do not have any problems, I also ground power supply grounds and make sure the service ground is on it.
    Al.
    Albert E.
  1. 5'x 9' CNC ground up.
    By gurvy in forum CNC Wood Router Project Log
    Last Post: 11-04-2008, 08:15 AM
  2. Ground Up
    By jabuffi in forum Mechanical Calculations/Engineering Design
    Last Post: 10-14-2006, 08:09 PM
  3. Motor supply ground vs Logic ground?
    By Gashmore in forum CNC Machine Related Electronics
    Last Post: 06-07-2005, 11:21 PM
  4. Power Supply ground question
    By chas in forum Gecko Drives
    Last Post: 04-16-2005, 12:48 PM
  5. To Ground or Not to Ground
    By Mr.Chips in forum Xylotex
    Last Post: 05-02-2004, 05:05 AM
