585,712 active members*
4,279 visitors online*
Results 1 to 6 of 6
    Jul 2003
    1754
    EMC 2.2.4 released
    You can read about it here..
    http://axis.unpythonic.net/
    make xxxmach exit reliably with 'halcmd unload' (SF#1816781)
    hook up encoder index for homing in the motenc sample configuration
    axis: don't reset the interpreter during touch-off and reload. This fixes the loss of modal settings from MDI, including tool length offset, fixing SF#1825638
    stepconf: clarify that it is the ratio of teeth on each pulley that must be entered
    hal_input: fix 'ZeroDivisionError' for absolute axes that report the same value for min and max
    fix various inaccuracies in the documentation
    halscope: fix the time displayed when mousing over a trace
    axis: fix ctrl and - or = starting an unstoppable jog
    axis: fix the numeric keypad with numlock on
    task: fix the initial coordinate system offset (SF#1895693)
    stepconf: fix "Both Limit"-type inputs (SF#1906640)
    stepconf: fix "HOME_SEQUENCE" problem without full set of home inputs (SF#1906641)
    stepconf: fix Z home and limit switches on lathes (SF#1910452)
    stepconf: fix 'offset' value calculated for spindle speed control
    stepconf: enable 'dither-pwm' for spindle speed control
    traj planner: fix velocity 'bobble' between 1st and 2nd consecutive synced moves
    halscope: fix 'sample every Nth time' function
    configs/univstep: fix external estop in this configuration
    pluto_step: fix for negative scale values (SF#1915407)
    pluto_servo: fix for pwm+direction mode
    stepconf: improve calculation of HOME_LATCH_VEL
    May 2005
    1662
    Do the gurus ever stop to sleep, go to work, etc?
    Good stuff as usual I'm sure.
    Anyone who says "It only goes together one way" has no imagination.
    Feb 2007
    514
    They work but don't sleep. My thanks to them for all the effort...
    John
    Mar 2006
    304
    That is a very thorough changelog! Good work to the crew who knows how to do all that programming!
    Damnit, now I have to rerig my network connection to get 2.2.4......
    Apr 2005
    1778
    cadmonkey,
    I just go to this URL and download the .deb ( emc2_2.2.4_i386.deb), put it on a thumb drive, take it out to the shop machine, copy it to the desktop and double click it.
    http://www.linuxcnc.org/emc2/dists/d...2/binary-i386/
    Alan
    Mar 2006
    304
    Thanks for the tip, I'll probably just wait since 2.2.8 will probably be out by the time I finish machining my ballscrews anyway :P
  1. Express Released
    By artcam in forum ArtCam Pro
    Last Post: 12-14-2007, 04:22 PM
  2. VCarve Pro 4.5 has been released.
    By bsimages in forum PhotoVCarve and VCarve Pro
    Last Post: 11-15-2007, 12:34 AM
  3. When Does X Get Released?
    By CAMCRASH in forum Mastercam
    Last Post: 04-21-2005, 08:23 AM
  4. TurboCNC 4.0 has been released!
    By chuckknigh in forum DIY CNC Router Table Machines
    Last Post: 08-27-2004, 04:55 AM
  5. MeshCAM 1.0 Released
    By robgrz in forum News Announcements
    Last Post: 06-01-2004, 02:55 AM
