Using Mach3
Please see a picture of my Home and Limit switches below.
As you can see each axis has two switches are wired in series.
The two switches on each axis, as I understand will act as limits and one of the two will be doing double duty as a Homing switch. This is programmable in Mach3.
OK now the question.
Since both switches of each axis are in series Mach3 must know by the direction of travel which switch is only a Limit and which switch is a Limit and a Home switch. Is this true? If it isn’t then I don’t see how Mach3 could tell which one was being opened in the below brawing?
