I would like to announce a push we are making at Northern Machining Inc. to try and test the marketability of our improved tap wrench.
Please visit the following link for more info: http://cgi.ebay.com/ws/eBayISAPI.dll...X:NEWLIST#LIST
To check out a video showing how it could be used in a milling machine, or drill press. http://northernmachininginc.com/tap%20demo.html
The most important realization to make, is that this design keeps the tap centered with the spindle in the machine. Not all taps come with a center hole for supporting the tap when running it in by hand, with a tap wrench. This causes one to try and tap without proper upper support and many times can result in a broken tap which can not only be expensive for the cost of the tap, but also can leave the broken tap in the part that is being worked on, which in alot of cases can only be removed with the use of an EDM which can be a very expensive process.
Our wrench gives multiple options for the upper support needed to remove risk of breaking a tap!
Thanks for taking the time to check out our product, and any suggestions or comments are welcome!
Regards,
Chad Ashley
[email protected]
