585,719 active members*
4,334 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > Centurion VI : Error 505
    Mar 2008
    Hello,
    We are working on a Milltronics VKM3 with a Centurion VI panel. We now have a problem that gives us "Error 505: Radius too small to span given points" when trying to load a G-Code program. Last time we had this, a correction of the tool's diameter eliminated the problem. Now, we are unable to clear this error and we cannot complete our parts.
    Please inform us about what is causing this particular error, and what workaround can be used.
    Oct 2006
    179
    An error 505 states that a radius is too small to span given points. Try using a larger diameter tool if possible. If using a larger tool is not possible, the program will need to be edited so that the start and end points are more than "R" distance apart.
    Mar 2008
    Hello jpawelk,
    Do I understand right that we need to eliminate the overlap in the circle we try to machinate?
    Mar 2008
    Hello,
    We still have the problem...
    Is there a place where we can download a complete manual, with error codes and workarounds?
    JF
    Oct 2006
    179
    Your start and end points of the arc need to be edited so that they are larger than the radius of the arc. Manuals are available through Milltronics parts dept. You can contact them @ 952.442.1401, option 3. Thank you
  1. Replies: 14
    Last Post: 12-10-2008, 06:34 AM
  2. Centurion 5 vs. Centurion 6 and validation codes
    By Turbo VW in forum Milltronics
    Last Post: 02-11-2007, 09:35 PM
  3. How Do I Calibrate MY Centurion 6?
    By TZ250 in forum Uncategorised MetalWorking Machines
    Last Post: 01-13-2007, 04:17 AM
  4. I'm Considering a Centurion 1
    By TZ250 in forum Milltronics
    Last Post: 09-07-2006, 08:30 PM
  5. Centurion 7
    By Enda in forum Milltronics
    Last Post: 01-26-2006, 01:00 AM
