585,981 active members*
4,229 visitors online*
Results 1 to 7 of 7
    Nov 2006
    12
    PCB Milling bits
    Quick question. I'm getting ready to make some PCB's using a CNC Taig and was wondering if anyone has experience with anything other than a half or quarter engraver bit.
    I see these things at the hardware stores all the time, and was wondering if it would be good for PCB. I'm guessing it won't work due to the shape of the tip, but who knows?
    http://www.dremel.com/en-us/attachme...=66240&I=66309
    Jul 2003
    1754
    I have had really good luck with http://www.thinktink.com/stack/volum...e/mechmill.htm
    around .007 isolations
    sam
    Nov 2006
    12
    I saw those a while back, will order some when I get a chance.
    Any preference for degree? 30/45/60
    My spindle can do 10,500rpm , what would be a reasonable ballpark feedrate to match?
    Nov 2005
    103
    http://drillbitcity.com/ -- resharpened bits a very good prices, IMHO.
    Aug 2005
    578
    bits
    Try your dentist.... he will have burrs and cutters made of carbide that he or she will donate for the cause. Most are used once and thrown away. if you can get a holder it is a never ending supply of mini engraving and cutting tools.
    Bob
    Jun 2003
    3312
    http://www.millpcbs.com/index.php?page=links Drewtronics bits for the price are pretty awsome. Feed rates depend on cutter size, spindle rpms, material removal and remaining material. At 25K rpm and 9mils of material removal, clean edges with a new sharp bit can be had at 12ipm. If the remaining trace width is wide enough you can go faster, as remaining trace width gets smaller you run the risk of tearing the remaining trace. For example if your leaving a 10 mil trace, you are taking chances at faster than 8ipm for the above example.
    Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
    Vist my websites - http://pminmo.com & http://millpcbs.com
    Jul 2004
    218
    Quote Originally Posted by blackbeard52 View Post
    That's still not a good enough reason for me to go to the Dentist.
  1. Frustrated: Breaking bits milling Aluminum
    By fivefishcnc in forum Uncategorised MetalWorking Machines
    Last Post: 07-19-2009, 12:38 PM
  2. milling bits
    By pike88 in forum WoodWorking Topics
    Last Post: 09-24-2007, 06:02 PM
  3. Luv those little bits..
    By CRFultz in forum DIY CNC Router Table Machines
    Last Post: 05-14-2005, 11:41 AM
  4. Milling bits for CNC mill....
    By studysession in forum Uncategorised MetalWorking Machines
    Last Post: 01-21-2005, 09:32 PM
  5. Where to buy CHEAP PCB milling bits
    By abasir in forum CNC Machine Related Electronics
    Last Post: 04-18-2004, 03:14 AM
