585,743 active members*
4,775 visitors online*
Results 1 to 11 of 11
    Sep 2006
    23
    Mach3 A axis (4th axis) setup?
    Hi
    I just finish my 4th axis.
    Now program basic rotation type in MDI:
    G0 A1.
    And it go 360deg.(one full turn) I expected to rotate 1deg.
    My system is:
    1. Servo
    2. Gecko drives G320
    3. Worm gear 40:1
    4. US Digital Encoders 500 counts
    5. Mach3
    6. In Mach3 for step I use 80000
    (500*4)*40=80000
    I like to set this that way so if I type:
    G0 A18. it rotates 18deg. not 18 full turns.
    How do I do that? Can be done?
    Or this is the way how 4th axis work.
    May 2006
    1469
    You need to divide the 8000 by 360 = 22.2222222
    Greg
    Sep 2006
    23
    Thanks Greg
    Did you mean?
    80000/360=222.22222
    Slawek
    May 2006
    1469
    Yeah I guess I missed a zero.
    In effect you want steps per degree, not steps per revolution.
    Mine happens to be 222.222222 also. Stepper motor at 2000 steps per motor rev and 40:1 worm drive reduction.
    Greg
    Sep 2006
    23
    Thanks again Greg
    Now can you tell me how did you deal with feed and soft limits?
    Slawek,
    May 2006
    1469
    Slawek
    By feeds I presume you mean velocity and acceleration.
    That just needs to be fiddled with till you get a setting that is reliable and you are happy with.
    As far a soft limits are concerned, I can't see that you would want to use them on a rotary axis.
    What would you set them at? Doing work that requires multiple revs in either direction?
    I will just leave soft limits off when using the rotary axis.
    I can imagine a case for wanting a home switch on it but I have not thought that far ahead yet.
    Greg
    Sep 2006
    23
    Hi
    I did mean to ask federate in nc program. And soft limits can you turn off only for A axis, I did not see this option in Mach3.
    I need soft limits for my X, Y and Z (I run machine with out limit switches)
    Slawek
    May 2006
    1469
    You can't turn soft limits off for only one axis. It is all or nothing.
    So what I would do in your case is set the rotary axis to a large number pos and neg.
    Eg, Soft Max 10000 and Soft Min -10000
    This should stop the rotary axis ever reaching the soft limit.
    Greg
    Sep 2006
    23
    Thank you for help
    Slawek
    Jun 2009
    G0 A1
    Yes, usually G0 A1 means one turn according to my postprocessor for ArtCam - it goes A-0.5 to A0.5 for full turn...
    Oct 2010
    448
    To remove Soft Limits on a rotational axis, set Soft Max. = 0 and Soft Min. = 0 and it will never trip the soft limits for the axis.
  1. Mach3 R3.00 Mill 4 axis Foam cutter setup
    By Andy Smith in forum Mach Mill
    Last Post: 01-25-2008, 02:19 PM
  2. Featurecam Lathe Setup X axis MAch3
    By whiteriver in forum FeatureCAM CAD/CAM
    Last Post: 02-21-2006, 12:04 AM
  3. Axis setup problem
    By ckrantz in forum Xylotex
    Last Post: 01-01-2006, 12:13 AM
  4. Z axis setup
    By MrBean in forum DIY CNC Router Table Machines
    Last Post: 09-26-2004, 05:55 PM
  5. Z Axis Setup
    By musicmkr in forum DIY CNC Router Table Machines
    Last Post: 06-10-2004, 05:33 AM
