585,997 active members*
4,844 visitors online*
Results 1 to 6 of 6
    Jan 2004
    668
    Sourcing Parts
    I need a good source for connectors. I need to connect my BOB to the control box via plug-in's on a panel face. What is a good connector for this app and where do I find them. Thanks in advance for any suggestions.
    Jan 2004
    668
    BUMP, What, no advice on plugs and sockets!!
    Apr 2003
    1873
    Speedre,
    Mouser.com has about any configuration imaginable, except probably the one you need.
    http://www.mouser.com/search/default.aspx
    Jan 2004
    668
    I looked on the key sites, Mouser, Digikey and such, but it's all tooooo much. I just need to know which connector types are most commonly used by cnc'ers.
    Jan 2006
    2985
    maybe a better description of what you want would help, as you say, there are way too many choices to narrow it down. Would DB connectors be a possibility? A lot of folks use them to connector motors and encoders to a panel of a control box.
    Matt
    Jan 2004
    668
    Well, my motors have a 4 conductor Molex connector that has screws for tightening the wires in, and the female is chassis mounted. Now, some of the solid conductor wire is showing at the terminus of the male, and, I'd like to add a cable chain and may need to add length. I also have added two wires to each axis Geko to the BOB which I'd like to change to shielded cable and a good sturdy connector also panel mounted. So, I'd like to make my connections all plug into a panel, X Y Z axis and X Y Z to the BOB, and its enable switch and Estop. All neatly arranged on a common panel in a enclosure.
  1. Sourcing Parts - help with selecting a shop
    By tikka308 in forum Employment Opportunity
    Last Post: 06-28-2007, 03:12 PM
  2. Replies: 34
    Last Post: 04-13-2007, 04:13 PM
  3. Out sourcing for molds
    By eddieliu007 in forum Moldmaking
    Last Post: 03-16-2007, 06:02 AM
  4. I need some help sourcing some equipment
    By eitanwaks in forum Linear and Rotary Motion
    Last Post: 05-20-2006, 10:59 PM
  5. Sourcing Hardware (1/8 Pin with threads)
    By Swami in forum MetalWork Discussion
    Last Post: 03-26-2005, 05:35 PM
