Hi all,
Using 1/8" Enco 2-flute, 3/8" LOC, 3/8" shank, uncoated HSS endmills on 6061-T6. Slotting at 1500rpm, 0.05" doc, 5ipm, the endmills are breaking. I'm also lubing with ATF. So I slowed down the feedrate to 1.5 ipm and that worked, but a simple part took 1.5 hrs!
I hear of people machining much faster than this, so is this related to my 1500rpm spindle? Should I use less DOC and faster feed? Is there perhaps a different type of endmill I should be using? Most other endmills talk about harder cutting edges, but I'm not sure if Carbide or other materials are actually stronger so that I can cut faster...???
Cheers,
-Neil.
