Got an angle grinder? Perfect for flat stock.
Check out Caswell Plating's site - they have pads for angle grinders - have been polishing up many pounds of stainless steel to very high gloss! The Aluminium will most likely loose it anodized surface if there however.
On the stainless I find that scotchbrite (type) pads tend to dull the surface finish with many scratches - I have been using the green and white bars of "rouge" and white high density pads. There is also a course sand-grit like pad that cuts through a lot of corrosion etc.
Hope that helps!
(BTW there are probably cheaper outlets for the materials - I got mine locally here in Malaysia - but wanted to get you to a site that is very helpful WRT polishing/buffing/plating)
:cheers: Jim
Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
