585,729 active members*
4,862 visitors online*
    Oct 2006
    65
    ball screw repair?
    hello all,
    i've bought an emco f1 a few weeks ago and i've spent some time to clean it and fix all kind of small problems. however, there is a major issue i don't know if i can fix by myself and i would appreciate expert advice.
    it seemed that the machine has trouble with the X axis, rapid movement is not smooth and i had a feeling that something was wrong with the ball screw. i took it out and seen that from time to time it stucks at points and only after some playing back and forth with it i can get it to move. i understood that the two nuts were not alligned and after removing the screw i even saw that some balls fell out. to fix it i took the enitre thing apart and cleaned it a little and tried to put it together myself, however i get that exact same problem. i don't know if this is a problem with the ball screw or maybe i just need a professional to fit it all together.
    i included a picture so you can see how the assembly looks like taken apart.
    Dec 2005
    436
    This problem could be dirt inside the nut, not enough balls, dents in the nut or screw or if there are two nuts they may be to tight against each other.
    You said you cleaned it " a little", to eliminate this question you have to completely disassemble it and really clean everything with grease cutting solvent and even compressed air, just don't loose any balls.
    Inspect the screw with a 10X magnifying glass and look for small dents made by the balls, you shouldn't see any.
    Count how many balls you hhave, and find out from the balls screw maker how many there should be, you don't want to be short more than a couple.
    If you remove the screw from the nut, it is normal for the balls to fall out. But reassembling is very tricky and has to be done right, with ALL the balls. Search these forums, this topic has been covered in depth.
    Sep 2008
    5
    When the nut is assembled to the screw, does it turn smooth? The nut should turn smooth without stuttering, sticking, or tight spots. It should be the same from end to end, without it sticking or getting tight or loose.
  1. what bearing fit with acme screw 1/2 -10(for cheap ball screw)
    By apex in forum Linear and Rotary Motion
    Last Post: 07-27-2007, 05:15 PM
  2. Belt vrs. Ball Screw vrs. Lead Screw
    By stevesplanes in forum Linear and Rotary Motion
    Last Post: 01-09-2006, 06:23 PM
  3. Help Repair ball screw
    By tivoidethuong in forum Linear and Rotary Motion
    Last Post: 12-19-2005, 02:55 PM
  4. New technology.... old debate.....ball screw vs lead screw
    By trubleshtr in forum Linear and Rotary Motion
    Last Post: 08-16-2005, 02:42 AM
  5. acme screw to ball screw question
    By Billw in forum DIY CNC Router Table Machines
    Last Post: 07-18-2005, 06:10 AM
