585,760 active members*
3,849 visitors online*
Thread: Gcode help
Results 1 to 9 of 9
    Feb 2004
    2337
    Gcode help
    What would be the Gcode to move an axis 100mm in a positive direction from where ever it is. I dont mean a Gcode telling the axis to go to a set spot like "G0z100" I mean a code that will say move 100 from where ever you are now. Is this possible?
    Being outside the square !!!
    May 2003
    79
    Try
    G91 G0 Z100
    G90
    This just tells the machine to make an incremental move (g91).
    Dont forget to switch back to absolute (g90)
    Mark
    http://www.weardalecnccarving.co.uk
    Feb 2004
    2337
    Thanks 4 that.
    Apr 2004
    60
    U and W commands (incremental) could be useful. For example:
    G00 U-1.8 W-3.1
    means that the tool should move -1.8 along the X axis and -3.1 along the Z axis (inches or mm) from the point where the tool was before the execution of the command.
    I don't think Mach2 supports this, though.
    Apr 2004
    60
    Sorry, I really had no idea...
    Feb 2004
    2337
    Hey Tex, I guess I should have mentioned Mach2 in the question.
    I think Ger must have already known thats what I use.
    Thanks for your contribution though.
    Apr 2004
    60
    It's OK....you're welcome...
    I was wondering if someone cold give me a list of g codes that will work on a bandt I control and tell me how to set the fixture offsets, i am familiar with coversational programming but not g code any help would be greatly appreciated
  1. Autocad to gcode
    By JamesMI in forum Autodesk
    Last Post: 12-02-2011, 09:54 AM
  2. Is it possible to get a gcode into Rhino
    By MrBean in forum Rhino 3D
    Last Post: 04-03-2005, 01:41 PM
  3. gcode to gcode converter
    By july_favre in forum Uncategorised CAM Discussion
    Last Post: 05-25-2004, 12:51 AM
  4. dxf to gcode problem...
    By freezer in forum Uncategorised CAM Discussion
    Last Post: 02-19-2004, 07:02 AM
  5. Gcode verify autocad plugin
    By balsaman in forum Uncategorised CAM Discussion
    Last Post: 10-31-2003, 06:22 PM
