It took some finding!!!!!!!! :tired:
Albert E.
LOL!!!!
You should post a splatter screen warning before doing that. I missed the monitor but now have coffee on the printer and wall.
Gary
Yes Al, it's good to fasten the cables so they don't dangle around. But it's not done correctly. You have to drive the nail about 30mm into the motor, then bend it over the cable to keep it fixed. That way you don't short the cable wires.
Or: use cable ties.
I'm slowin' down - it took 3 reads - but I didn't LOOK first 2 - to get it - NOW i can't stop laffin!!!
Spike! Einar gave it away for me
Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
I have a deck to build - where can I buy these interference spikes?
would they be in the electrical department?
maybe...
Al,
I guess you could say you have nailed the problem did it cause a hamering effect on the lead screw
"A Helicopter Hovers Above The Ground, Kind Of Like A Brick Doesn't"
Greetings From Down Under
Dave Drain
Akela Australia Pty. Ltd.
