I have a Harbor Freight 9 x 20 lathe. I was turning down a piece of CRS using the automatic feed lever. I made several passes and after each pass I would disengage the feed lever and return the carriage to the starting point. On about fifth pass the carriage did what it was supposed too do but when I released the feed lever I could not return the carriage to the starting point. It jammed and after checking it out I noticed a piece of square stock about 1/8" sq and approx 1" long laying in the long slot of the lead screw. Please refer to the attachment (jpg) which is a copy of page 37 of the H.F. Instruction Book .
My guess is that this small piece of steel is the key (Item 4)that somehow controls the worm gear (Item 3). I also abserved that the three screws that hold the bracket (Item 2) in place were loose which leads me to believe is the reason the key to fall out.
What can I do to replace this key any comments recommendations greatly appreciated.
John Romano
