585,760 active members*
3,717 visitors online*
IndustryArena Forum > CAD Software > Autodesk > Dumb AutoCad Question (Open window won't come up)
Page 2 of 2 12
Results 21 to 25 of 25
  1. #21
    Mar 2009
    1982
    I will explain my question other way. I have about 400 drawings to check and maintain. Some corrections must be done and I do automated printing (plot). Drawings are framed as for paper version. Some drawings contain (garbage) elements outside the frame. I use the command to pan view so, that I see entire drawing instantly in XY plane. If there is something outside the frame, it's easy to note and delete instantly. What the command is?
  2. #22
    Zoom window?
  3. #23
    Mar 2009
    1982
    what You do to find invisible garbage? You don't know layer, You don't know size, You don't know location (coordinates).
    If You know someone working with P-CAD, the comand is "lpan".
  4. #24
    Zoom Extents will show everything.
  5. #25
    Mar 2009
    1982
    That's right. And what You do if view is some wierd spatial angle?
Page 2 of 2 12
  1. AutoCAD "How-To" Question
    By studysession in forum Autodesk
    Last Post: 02-15-2011, 02:40 PM
  2. AutoCad 2000 DXF Question
    By Holmes_ca in forum Autodesk
    Last Post: 01-20-2005, 12:50 AM
  3. Dumb Protel Question
    By RXTurbo in forum CNC Machine Related Electronics
    Last Post: 07-29-2004, 11:58 AM
  4. dumb question
    By rob1215 in forum Uncategorised MetalWorking Machines
    Last Post: 06-24-2004, 06:27 PM
  5. Autocad question
    By rocketguy in forum Autodesk
    Last Post: 02-18-2004, 02:23 AM
