585,748 active members*
3,673 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > DNC Help Please on VMC15
    Nov 2007
    78
    I have an older 93 VMC15 with 1400-4 cards.. so, this makes it at early 96 firmware.
    I have been trying to get the DNC working. I have finally out grown my little memory area.
    I can load the smaller programs to the machine with Cimco V5 and even ConnectCNC.. I put in the TA,1 and we have great communication..
    However when I go to DNC, I get some strange things.
    Cimco will start to load the program and get to line 320, and the Fadal screen shows it just stops taking any more lines of code.
    ConnectCNC will start to load the program and get to line 290 of the same above program and the Fadal screen shows it stops taking lines of code there.
    I dont get any errors displayed.. it just stops taking lines of code.
    If I start to play with the parity, I start to get errors. If I change the baud rate from 9600, neither program will work. It seems that 9600 is the only setting that wants to work. I dont understand why 4800 wont work really on transferring a program, but it will not.
    I am starting to think I have a bad communication card in the machine, but maybe it is just a software setting.
    here is the few lines of code it is taking via DNC.. if I cut this program to line 5000, I can load it fine and run it as a resident program on the machine.
    N120G20
    N130G0G17G40G49G80G90H0E0Z0
    N140G28Z0.
    N150G28X0.Y0.
    N180T3M6
    N190G0G90S222M3X-1.2847Y-.1442
    N200H3Z1.M8
    N210G1Z-.03F4.
    N220G3X-1.3105Y-.22I.2758J-.1363F6.
    N230G1Y-.3444
    N240G3X-1.2847Y-.4248I.3367J.0639
    N250G1Y-.0221
    N260G3X-1.3105Y-.0527I.2758J-.2584
    N270G1X-1.3097Y-.5209
    N280G3X-1.2825Y-.555I.3359J.2404
    N290G1X-1.2847Y-.4881
    N300Y.0729
    N310G3X-1.3105Y.0511I.2758J-.3534
    N320G1X-1.3008Y-.6364
    N330G3X-1.2742Y-.6592I.327J.3559
    N340G1X-1.281Y-.5978
    N350X-1.2847Y-.4881
    N360Y.1587
    N370G3X-1.3105Y.1413I.2758J-.4392
    N380G1X-1.2866Y-.7374
    N390G3X-1.2593Y-.7549I.3128J.4569
    N400G1X-1.269Y-.7052
    TIA....
    >L
    Jan 2004
    3154
    It sounds to me like your send settings need to be tweaked.
    I suggest you set send type to line and not to buffer.
    I haven't touched my settings for a few years, so my memory may be off.
    I DNC to my 94 fadal at 19200 baud.
    You have to change the SetP parameter (for baud) and then power down the machine (once you are back to the MDI screen) for it to take.
    I find 9600 baud really starves the control when you have really small moves like when "surfacing"
    www.integratedmechanical.ca
  1. Vmc15
    By multex1 in forum DNC Problems and Solutions
    Last Post: 04-17-2007, 10:13 AM
  2. Where to buy VMC15 relay
    By melzer in forum Fadal
    Last Post: 02-11-2007, 04:36 AM
  3. Single phase back to 3 ph VMC15
    By davisboys in forum Fadal
    Last Post: 04-06-2006, 01:26 AM
  4. Drawbar spring question on fadal vmc15
    By Edster in forum Fadal
    Last Post: 02-10-2006, 04:47 PM
  5. Polychain belt conversion for VMC15
    Last Post: 02-08-2006, 04:42 PM
