585,997 active members*
4,727 visitors online*
    Apr 2005
    7
    Ace depth problem
    No matter what I put in to Ace for the Z offset and max Z pass values, the G code always comes out with a Z offset of 0.09448031 . What have I done wrong?? It had been working fine for years up until now.
    Not sure, but make sure the entities in your .dxf file are drawn at Z=0. If they are not drawn at Z=0. the offset from zero appears to get added to the final depth.
  1. What RPM/Depth of cut?
    By sp1nm0nkey in forum Uncategorised MetalWorking Machines
    Last Post: 04-08-2007, 04:45 AM
  2. problem with depth in v carve
    By timmyb199 in forum Vectric
    Last Post: 11-01-2006, 06:42 AM
  3. Problem with drill depth
    By Alan S in forum Post Processors for MC
    Last Post: 11-03-2005, 09:23 AM
  4. Npt Depth
    By ryanduc in forum MetalWork Discussion
    Last Post: 06-23-2005, 10:24 PM
  5. rotary 4 ax depth of cut q.
    By nervis1 in forum Mastercam
    Last Post: 03-24-2005, 11:34 PM
