Is the pantograph a machine that follows a metal template?
That is what we call them in the US.
If so, it may not be able to go fast enough for a plasma and THC.
If your cutting speed is slow then the height control will dive into the plate, or cut much closer than you want. Also the Kerf will be wider and your parts may be undersized.
Just something to watch out for.
If you can use it then the Sensor PHC will work nicely on the Max-200.
I have installed a few this way and they work great.
Good Luck,
Alan Bradford
www.plasmatechnologies.com
