585,956 active members*
4,560 visitors online*
    May 2008
    5
    Question Have Question about Anilam 4200t Offline
    :withstupi Does anyone know if the run time is correct when you are checking a program on a PC with Anilam 4200t Offline software. The Feedrate is correct but it says the program runs in 55 seconds, It should run in 10 to 15 Minutes. Help Please. Large Threaded part feedrate is correct to spindle speed but time is WAY SHORT???????????
    Aug 2008
    Hi everyone,
    I have an Anilam 4200 it was running just fine I opened the panel box and looked to see where a cable was pluged in and when I started the machine back up it does not boot into the program screen it comes up with CRC error reading drive C does anyone know what this means and how to get passed it?
  1. Anilam 4200t Offline software, anyone have it?
    By racingdave in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-08-2021, 09:44 PM
  2. Mach2 offline only
    By mayhugh1 in forum Mach Mill
    Last Post: 10-01-2006, 05:59 AM
  3. trakcnc2 offline HELP HELP HELP
    By shunter1625 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-11-2005, 06:28 PM
  4. Trak CNC 2 Offline System
    By seb fontan in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-25-2004, 07:11 PM
