585,743 active members*
4,958 visitors online*
IndustryArena Forum > CNC Electronics > Phase Converters > kavo 4444 remote control
    Jan 2004
    45
    I have a kavo spindle and driver (4444) mounted on my Tormach mill, and would like to use the remote control features of the driver accessed via a 25 pole subd connection. Unfortunately the manual contains only the most basic description of the connection. It aludes to much greater detail and function but doesn't supply the detail, the damn teasers!
    Thus far the US dealer has not been forth coming, likely because this is a discontinued model etc.
    Do any of you have this info?, If so I would appreciate any assistance.
    Thanx
    Wayne
    Dec 2005
    21
    It is indeed very hard to get any information about this converter, however I've managed to receive some pages of the technical manual of the EWL-4444.
    It is in german, but I think it is prety clear..
    Let me know if you run into any problems.. (I can translate if needed).
    I have the same converter, and also want to connect it to my CNC-computer.
    Attached Files Attached Files
    Re: kavo 4444 remote control
    I have one of these as well and would like to control it with an arduino.
    Nov 2009
    I have been looking for this solution for years. I have gotten it to work recently. The trouble is the drawings are not correct. You want to use pin 1 as the common for shorting out pin 3 for start and pin 15 as the stop. These are only needed momentarily and act exactly like the front panel buttons.
  1. kavo/syco drill control unit
    By derrick123 in forum PCB milling
    Last Post: 03-03-2013, 08:43 PM
  2. kl-600-48 Remote control?
    By Pplug in forum Automation Technology Products
    Last Post: 08-24-2011, 01:25 AM
  3. Remote control for WaterJet
    By Twil759 in forum News Announcements
    Last Post: 09-03-2008, 10:49 PM
  4. Remote Control Pad Help!
    By Cartierusm in forum Mach Software (ArtSoft software)
    Last Post: 10-26-2007, 10:24 PM
  5. non RF remote relay control?
    By DennisCNC in forum CNC Machine Related Electronics
    Last Post: 07-08-2006, 11:15 PM
