585,894 active members*
5,026 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Stepper motor size needed??
Results 1 to 19 of 19
    May 2008
    9
    What power/ oz in, stepper motor would be best for direct drive on a HF 42827 model geared head mill drill conversion.
    Thanks for any help.
    Joe
    Mar 2008
    3655
    Two questions:
    1. Do you already OWN this mill, or are you just planning to buy it?
    2. What do you plan to DO with it?
    CR.
    May 2008
    9
    re
    I already own the mill, I would like to get some light to medium production work out of it, making small airgun parts, but for the most part it will be an educational stepping stone to a better machine.
    I was looking at 2 kits on ebay, one consists of 425 oz in steppers and the other 1200 oz in steppers.
    it would be nice if I could get by with the 425's because of price but also dont want to spend the money if they wo'nt have what it will take.
    Thanks for your time
    Joe
    Mar 2008
    3655
    It must be said that a round column mill is a poor candidate for CNC conversion. You might be better off in the long run to buy another mill--like a Grizzly X3 or SX3.
    That being said, you need to estimate the force required to turn the respective axis cranks. For example, measure the radius of the X axis wheel and multiply that times the force necessary to TURN that wheel.
    Stepper motors are measured by the peak torque, which is what the motor puts out to hold it still. As RPM goes up, torque falls off rapidly until, much too soon, the motor stalls under the load.
    How fast do you want the axes to move in air from one cutting point to another? (rapids) How much force will you need to exert on the work during cutting? How do you intend to wire your motors? Bipolar parallel gives higher rpm. Bipolar series gives more low speed torque. Both are more powerful than unipolar.
    Even as important as oz inch ratings is the POWER SUPPLY you intend to use. A good rule of thumb is to use a power supply about 20 times larger than the motor's rated voltage. Less, means lower speed and torque. Higher voltage (within the driver limits) charges the coils quicker so gives better performance.
    So, for example, if you have a 425 oz motor rated at 4 volts and drive it with a 24 Volt power supply, you will get less performance than if you used a 200 oz motor rated at 1.5 volts with the same power supply.
    CR.
    May 2008
    9
    re
    http://cgi.ebay.com/3-Axis-Stepper-M...QQcmdZViewItem
    theres the shortcut to the item I was looking at.
    I'm not going to lie I know very little about this subject but I am very interested in learning and I have to start somewhere, and This seems to be the best place to start, hopefully that link works they have the specs listed, but I dont know enough to know if they are what I need.
    Im not to concerned about speed and power just need it to work well enough so that I can get a good education out of the money I might spend on it.
    Joe
    Feb 2007
    4553
    Joe,
    The kit you are looking at will work for your mill, you might want to upgrade the power supply to this model KL-350-48 it will double the performance of the steppers for a additional $30.00 .
    You can use pulleys for the X and Y axis to double the torque go with 2 to 1 reduction.
    The 425 oz stepper will be more than enough for the quill on your machine.
    Jeff Alessi
    Mar 2008
    3655
    OK. You have to start somewhere. But you are not ready to consider steppers yet. How do you intend to MOUNT them to your mill. I don't know of anybody making conversion kits for that mill, so are you ready to fabricate mounts yourself?
    Back to the Keling kit: These "kits" cost almost as much as the individual components. They are a good deal pricewise, but not performance wise--As configured. But, you can mix and match as needed and upgrade the price slightly.
    Keling website:
    http://kelinginc.net/
    In order to get the full POWER out of the 425 oz (4V * 20 = 80 V) steppers--you would have to upgrade to the $190 72 volt power supply. But THAT would exceed the driver voltage. The 48 V Power supply would work with the drivers.
    You would actually get more power by substituting the 282 Oz steppers which run quite well on 24 volts.
    But you haven't determined the force requirement for the mill yet. No sense making mounts for Nema 23 size motors if you actually need Nema 34 size steppers.
    CR.
    May 2008
    9
    Thanks for the info Jeff.... Nt
    nt
    Feb 2007
    4553
    conversion parts
    Joe,
    There is a company "www.microkinetics.com" that makes a retrofit kit for your mill that uses 2-470 and 1- 350 oz stepppers and 2 to 1 pulley reduction for X and Y axis.
    They charge about $4,300. for the kit.
    There are several people on the CNCzone that have made the stepper mounts etc...
    Take a look at these images, they will give you some ideas to start with.
    The last set of images is interesting also.
    http://pashupatina.com/gen2/album/
    http://ivan.pashupatina.com/cnc/cnc_2/images/
    http://tinyurl.com/5d6yh6
    May 2008
    9
    re
    Sure the mounts wont be a problem for me.
    So looks like what my next move will need to be is to estimate the force needed.
    One question, that is the force required to turn the shaft at the actual shaft dia and not at the outside handwheel dia right.
    Thanks for all the info it is greatly appreciated.
    Joe
    May 2008
    9
    re jeff
    Thanks Jeff
    I'll check it out.
    Everything helps to form the final plan.
    Joe
    Feb 2007
    4553
    Joe,
    This is a good read.
    http://tinyurl.com/42rdao
    Mar 2008
    3655
    Quote Originally Posted by btrager1978 View Post
    Joe
    Yes, but it is easier to MEASURE the force at the outside diameter. Then you can, multiplying by the radius, translate the force to the shaft diameter.
    The force will change depending on whether you use ball screws or the stock Acme screws. Ball screws are super easy to move and retain little backlash. Acme screws need to have gibs and anti-backlash nuts fairly tight to reduce backlash--and consequently need more turning force.
    CR.
    May 2008
    9
    Jeff
    I checked out the last set of images, some usefull ideas for sure.
    I agree the tweak to eliminate the head, side to side movement is interesting, I will look into that some more, I think the part with the bearings wouldnt hurt to be built with some more beef, definitly a good idea. It's also got a few other brainstorms started that I'll have to look into.
    Thanks, this is getting more fun the deeper I get into it and I still have a ways to go :-)
    Joe
    Feb 2007
    4553
    Joe,
    You will have to know what type of screw you will be using before you determine the stepper force requirements.
    If you are not looking for maximum performance it is not that big of a deal as long as you don't under size the steppers to much.
    There have been so many RF31 type CNC conversions done already using 425 motors with pulley reduction, so that wont be a issue.
    If you did decide on direct drive you might need a bigger motor maybe if the ways are super super tight.
    Pulley reduction will slow down the fpm however you wont ever machine that fast anyway!
    There are guys using 250 oz servos with pulleys that have snapped off 3/8 tooling.
    If you have a 5 tpi screw and 2 to 1 pulley reduction you have 156.25 lbs of force.
    That is a lot more that you will ever need.
    May 2008
    9
    C. R
    Ok, yeah That makes sence, I'll do that.
    I tryed a tweak to help eliminate backlash on the stock screws, it has done wonders useing it in manual mode, It involved pressure fitting delron rods from both sides in the nut,so the leadscrew rides mostly on the delron for minimum friction and backlash.
    Thought it will be worth giving it a shot, I can always upgrade to the ballscrews if needed.
    Joe
    Feb 2007
    4553
    Joe,
    I may have jumped the gun a bit suggesting stepper torque values because when I hear cnc conversion I assume "ball screws"
    Due to the inefficiency of the stock lead screws the torque requirements are larger.
    Jeff...
    May 2008
    9
    Jeff
    No problem I'll look into that tommorow and see what I come up with. I know this doesnt give the info needed yet, but with the delron tweaks i did on the nuts it turns much easier then it was turning with the anti backlash screws adjusted to were the backlash was somewhat manageable.
    I'll have to measure the backlash, to the eye i cant see any so it has improved considerably.
    joe
    Mar 2008
    3655
    I'm sure YOU know this all Joe, but some may not:
    BACKLASH: When reversing direction, any handle movement that does not also move the axis (or table or head/quill) is backlash. It is measurable directly by the dial on the handwheel.
    For CNC, backlash must be checked and adjusted often. Backlash will turn a circle into a vague blob..
    ACME SCREWS are the standard for most manual mills. They are just a relatively close tolerance screw thread and give fairly high precision and backlash while the adjustment lasts.
    Acme screws and nuts wear quickly. Usually the screw wears most in the middle and less on the ends. After a while, you can't use the ends because it's too tight.
    Even relatively cheap ballscrews, which HAVE some backlash, are better because the backlash does not vary so often. Mach3 (The hobbiest defacto best computer software for machine control) can compensate for backlash that doesn't keep getting worse
    BALLSCREWS have large threads that allow a ball bearing to roll IN them. The ballscrew nut contains many small steel balls that recirculate inside to reduce friction. The ball nuts can be extremely tight to eliminate backlash--yet still have little friction.
    Once ballscrews are installed, manual control is lost. Because ballscrews turn so easily, the table or head will not hold a position, but is free to move on its own. So while you COULD install hand cranks on double shaft motors, you would have to constantly lock the gibs on the other axes and it's just not practical.
    Ballscrews come in two types: Rolled and ground. Ground ballscrews are best, but can cost thousands of dollars for just one screw. We small-time automators usually can't afford them.
    Rolled ballscrews come in several grades. The better they are for accuracy and low backlash per length, the more they cost. We usually use a medium grade.
    If you buy say a six foot length of ballscrew, it needs to first be cut to axis lengths. It is hardened material, so this is usually best done with an abrasive cutting disk.
    After they are cut, each end is turned down on a lathe. Because they are hardened, this is difficult to do. One end is usually turned to one diameter to fit a bearing. The other end may be turned to several decreasing diameters to accomodate thrust bearings, threaded for clamp nuts, and turned at the end to fit stepper coupling or pulley.
    Once you have determined the LENGTH of the screws you need, there are companies who will make your ballscrews to order.
    PULLEYS are used to increase torque by gearing down the motor RPM. However, stepper motors get weaker as speed increases, (To a limit of 800-1500 RPM depending on PS voltage--up to 20-25 times motor rated voltage if the drivers can handle it.) so most of the gain in torque results in lost speed. That's why most stepper motors are connected direct drive.
    STEPPER MOTORS usually have a hardwired step count of 200 per revolution. At this FULL STEP resolution, 200 computer pulses will turn the motor once. Micro stepping theoretically increases accuracy at the expense of speed, and promise extremely high accuracy by increasing steps per revolution, but practically 8 or 10 microsteps are the limit. There is a limit to how many pulses the computer can put out, and the higher the step count, the slower the motor will run.
    SERVO MOTORS, which are more expensive, do not have the starting torque that steppers have, but they maintain what torque they have into high rpms. They are usually geared down 2 or 3 to 1 to gain starting torque. Even geared down, they can still attain thousands of RPM, so speed is not a problem with pulleys.
    Servo motors are also equipped to tell the computer (through encoder feedback) exactly where the motor is at any given time so there are no missed steps. Stepper motors can stall and miss steps unbenownst to the operator until the finished part is measured.
    Each system has its pros and cons. Steppers used with proper power supplies are reliable, consistent and cost effective--That's why most hobby applications use steppers.
    NEMA SIZES: Both steppers and servos may come in different Nema flange sizes. We usually use either the smaller Nema 23 or the somewhat larger Nema 34. The torque may overlap between the sizes, but generally the larger motor has an easier time.
    For example, a 500 oz Nema 23 stepper motor will be working hard (and getting hotter) to attain the torque at which a 500 oz Nema 34 will be easily cruising. Generally, power is added by extending the length (stack) of the motor.
    CONTROL DRIVES: Stepper drives are the electronics that translate the pulses from the computer into useable current for the motors. They are fairly expensive and many are subject to being destroyed easily.
    Generally, the more expensive drives offer the best features like overheat protection, micro stepping and speed morphing. Steppers tend to get hottest standing still. Morphing drives micro step at low speeds but vary to full steps at high speed.
    Actual expensive commercial servo drives use a different system than stepper drives, but OUR affordable servo drives use basically the same pulse system as stepper drives.
    GECKO DRIVES are generally acknowledged as the best. Gecko "Vampire" drives are virtually unkillable.
    BREAK OUT BOARDS: Mach3 uses the many wires in a parallel port (printer) cable to send control from the computer to the drives. Rather than fastening each tiny wire in the cable to its destination, the breakout board accepts the cable plug and then puts each wire on an accessable screw terminal.
    The new low-cost Gecko G540 board will combine tiny cheap drives with a "Vampire" breakout board so that all you need to connect is the parallel cable, power wires, and motor cables. In a couple of months, CNC conversion is going to be a LOT easier.
    CR.
  1. size of stepper motor
    By sanjiv in forum Stepper Motors / Drives
    Last Post: 04-27-2008, 04:42 PM
  2. what size stepper motor?
    By nikbrewer in forum DIY CNC Router Table Machines
    Last Post: 01-19-2008, 08:45 PM
  3. Stepper motor size
    By corydoras in forum Open Source CNC Machine Designs
    Last Post: 10-22-2006, 05:13 AM
  4. stepper motor size
    By nymachinist in forum Mini Lathe
    Last Post: 02-21-2006, 11:34 PM
  5. How to figure needed stepper motor size?
    By Hack in forum CNC Machine Related Electronics
    Last Post: 07-19-2004, 09:43 PM
