585,690 active members*
4,535 visitors online*
Thread: TL 1 trouble
    May 2008
    TL 1 trouble
    any thoughts on why my TL 1 will turn my first programed dia. and be off .02 to .03 on the second dia.? I'm using one tool with no interruption.
    Jul 2005
    181
    To help you, I would like to see your code.
    Jul 2005
    12177
    I had a similar problem once, and the cause was really simple; the insert was a bit loose and could rotate in little bit in the holder. Before getting involved in anything more comlicated just make sure your holder is clamped tight and the insert is in correctly and tight.
    May 2008
    thanks for the suggestion, but i did check the insert first or second. but thanks. i did have a x servo too large alarm last week and the service guys think in may be that motor or it's interface.
  1. Trouble
    By extreme in forum DIY CNC Router Table Machines
    Last Post: 07-11-2010, 10:14 PM
  2. The trouble with SE
    By split63 in forum Uncategorised CAD Discussion
    Last Post: 10-24-2008, 05:59 AM
  3. More PIC trouble
    By robe_uk in forum CNC Machine Related Electronics
    Last Post: 10-10-2006, 09:13 PM
  4. Arc trouble
    By Graeme in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-24-2005, 09:31 AM
  5. having trouble getting this to cut right
    By MIKENLN in forum BobCad-Cam
    Last Post: 04-19-2005, 08:24 AM
