585,973 active members*
3,945 visitors online*
Page 1 of 2 12
Results 1 to 20 of 21
    Mar 2005
    73
    CAM T4 Mazak Mazatrol optional parameters
    Does anyone have any information on the optional parameters on page 4 of the T4 parameters?
    "Fire is cool" -Beavis
    May 2008
    8
    t4 option parameters
    go to diagnostics page, cursor to wh, input 1640a0, input, cursor right, input ff, go back to parameter page, will be accessible now
    DD
    Mar 2005
    73
    I know how to get to them (thanks anyway) I need info on the optional parameters on that page.
    May 2008
    8
    t4 parameters, options
    if you have your electrical prints, it wiill show the option parameters and have sub notes. these sub notes tell you what page the option parameters are located, for instance sheet 142, 143,145. On those pages, you will see exactly what each option parameter is. You will have to determine which of these options your machine has, such as normal chuck, japan chuck, and put the correct bits in the option parameter
    Sep 2008
    22
    no found the feed
    when attempt to do what you say, and passage to the position page clears the FF to him
    Apr 2010
    Option Parameter T4
    How to access the option parameter ?
    __________________
    Mar 2005
    73
    I think it is a typo FX27 instead of 727. FX01 is the board w/ the dip switch you pull the board flip #2 if memory serves correct, replace board power on 5 seconds off 5 seconds. Usually 1 time will work but sometimes not, go ahead and power on off 3 - 5 times for good measure, power off flip switch 2 back to original position w/out removing board and power on. Done.
    Sorry wrong thread......
    Mar 2005
    73
    Quote Originally Posted by tonny2105 View Post
    __________________
    Probably have to select diagnosis display, position cursor at WH and type 1640A0 & input. Move cursor to right type FF & input. Then go back to paramter pages and scroll to the fourth page. After editing anything on this page you must turn the control off and back on for changes to take effect. I hope this works for you. Like I said in another post I have been through alot w/ this control. Also, if your spindle drive craps out 1 to many times like mine did let me know and I will talk you through replacing it w/ an aftermarket unit that will be completely trouble free for approx $1500.00 US or ask me to ship you the pallet of spare parts I have for that drive....
    Mar 2005
    73
    Also, if you can access page 4 parameters and are just having problems w/ changing optional parameters you must type in the 0's or 1's for the whole string (8 characters I think) and then type in the number of parameters that are 1's (on). For example:
    00000000 last digit would be 0 because there are no on bits (000000000)
    10000000 last digit would be 1 for 1 on bits (100000001 & input)
    10000001 last digit would be 2 for 2 on bits (100000012 & input)
    10001001 last digit would be 3 for 3 on bits (100010013 & input)
    etc....
    Press input after each bit string and number of on bits.
    One of these parameters tells the control how much memory it is equipped w/ and nothing will work until you change it, power off, and power back on. Then your hydraulics will come up and you can move on to the next problem!
    Apr 2010
    Smile
    Quote Originally Posted by machinist360 View Post
    HELLO FRIEND,
    thank you your Info is work.
    but I still have Problem with the alarm 22 NMI Memory Parity Error.
    I have Loaded new Parameter by Hand also C Cond,Tool Data and Tool Set.
    How to clear Alarm 22 ?
    Mar 2005
    73
    Glad to hear that worked for you. You probably get the Alarm 22 NMI memory parity error every time you put the machine in automatic mode and press cycle start. If you do the reinitialization every time you turn on the machine it will probably run, but of course that is not the best solution. Contact the guys at Mitsubishi Electric www.meau.com and describe the problem. They can fix the offending board for $300.00 US and it was well worth it in my case. Let me know if there is anything else I can help with!
    Sep 2008
    22
    parameters optional
    hello,
    no hablo ingles espero me puedas entender
    te vas a parameter
    3 2 1
    solo debes de presionar el tercer boton (back page, next page)
    presiona 1131
    imput
    ahi te deben salir los parametros opcionales
    traduce con google
    jorge viloria
    Mar 2005
    73
    Quote Originally Posted by jlviloria@gmail View Post
    hello,
    te vas a parameter
    3 2 1
    presiona 1131
    imput
    traduce con google
    jorge viloria
    Gracias muy bien
    Apr 2010
    The Machine not yet run untill this alarmm 22 clear I think.
    How to Clear all Parameter because has some parameter can not change so I want to clear first all the Parameter.
    Do you have an Option Parameter for CAM T4 ?
    Thank you
    Apr 2010
    Thank you
    Mar 2005
    73
    Thank you
    Inch or Metric?
    Apr 2010
    Inch or Metric?
    I need Metric.
    How to clear all the Parameter to 0 (zero)
    Thank you
    Mar 2005
    73
    I need Metric.
    Thank you
    That is described in the service bulletin I posted.
    Sep 2012
    Does anyone have any information on how to change optional parameters on mazak cam T2 ?
    Sep 2012
    Does anyone have any information on the optional parameters on page 4 of the T2 parameters?
Page 1 of 2 12
  1. optional parameters for 3T
    By joachim in forum Fanuc
    Last Post: 10-31-2018, 08:13 PM
  2. Replies: 3
    Last Post: 07-19-2017, 09:16 AM
  3. Hardinge Conquest T 42 FANUC 0T optional parameters
    By bobancurug in forum Hardinge Lathes
    Last Post: 09-20-2015, 04:17 AM
  4. I need help! Mazak Quick slant 20 mazatrol T-4 Lost parameters.
    By Iliyan in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-17-2013, 06:54 PM
  5. Mazak Vqc - Machine Parameters In Mazatrol
    By markodacosta@ne in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-10-2009, 10:20 PM
