584,858 active members*
4,583 visitors online*
    Jun 2007
    13
    G code help C-X axis
    Hello to everyone. I'm a new poster and need some G code help. I am a wood gear clock builder who is tired of hand cutting gears. I'm exploring the possibility of adding CNC to my old Rockwell mill. the problem that I have is that the Y axis travel is too small for the gear sizes I want to cut. One solution is to use a rotary axis (C) along with my X axis to cut the gear tooth profile. I'll be using either Turbocnc or Mach2mill to drive my controller. I will be cutting epicyclic gear profiles. With wood gear clocks that profile is often approximated as a circular arc segment. I have written g code using g2 and g3 for cutting using the X and Y axes and the code looks good in a simulation. I need to do the same thing now using the C and X axis and am not sure how to set this up.......Help me please.
    Steve
    Feb 2008
    267
    Don't know a thing about the controllers you mentioned.
    The method you are looking for is "Milling Interpolation" which translated the Catresian XY system to Polor Coordinates.
    You would implement the Milling Interpolation G-Code then use the G2/G3 X/Y code you've already simulated, the control would translate to X/C moves to generate programmed profile.
    Good luck!
  1. 4 Axis CNC - MS Excel Source code (VBA)
    By arman in forum Visual Basic
    Last Post: 03-06-2018, 01:37 AM
  2. Need g-code for 4 axis semi-spheres.
    By jaru-eri in forum Mach Software (ArtSoft software)
    Last Post: 04-30-2008, 02:49 AM
  3. zero axis key code?
    By drafterman in forum Mach Software (ArtSoft software)
    Last Post: 03-06-2008, 03:18 PM
  4. Z-Axis Arc G-Code?
    By GTmike400 in forum G-Code Programing
    Last Post: 01-27-2006, 06:15 PM
  5. using bobcad to create c axis g code?
    By stuart76 in forum BobCad-Cam
    Last Post: 08-15-2005, 11:06 AM
